Aeroforce intercepter instead of boost gauge
Old Dec 2, 2009 | 03:03 PM
395 plus's Avatar
I have an aeroforce gauge and it has a boost reading on it. What I want to know is will it display the boost accurately (as well as stock boost) or will I need to keep both gauges???
Old Dec 2, 2009 | 03:04 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the interceptor does not read boost correctly. its way off
Old Dec 2, 2009 | 07:15 PM
Gene Culley's Avatar
Talking
Yes, the max boost it says I have is like 2 PSI.
Old Dec 2, 2009 | 07:20 PM
ziggity's Avatar
Mine seems to read my boost fine.
Old Dec 2, 2009 | 08:37 PM
stonny9's Avatar
Mine read the same as the factory guage when I had them hooked up at the same time. Yes I know that the OEM guage isnt totally accurate and is digital.
Old Dec 2, 2009 | 09:08 PM
HunterKiller89's Avatar
it SHOULD read boost fine if you have a 2.5 bar MAP sensor and are tuned for it. For us NA guys who are boosted, but still running the stock 1bar MAP sensor..of course it wont show boost.
Old Dec 2, 2009 | 09:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
my stock boost gauge was reading 16psi and my interceptor was at 11psi. engine vacuum as way off as well. the car would idle at 16-17inHg and the interceptor would be at 9-10. i dunno. lol
Old Dec 3, 2009 | 12:31 AM
SSfamilywagon's Avatar
When I had both my interceptors and the factory boost gauge, they read the same in boost and vacuum.
Old Dec 6, 2009 | 03:00 AM
crstud84's Avatar
ive had dual interceptors for about a year now on my redline, guages read boost and vacuum fairly accuratly. I can see issues with the readings with people who have custom tunes. With all the other info the guages give you, slightly off boost readings are forgivable...
Old Dec 6, 2009 | 12:20 PM
Talking
Hey Casey, thanks for the reminder on that. I don't believe I have tried it since I've done the 2.5 bar MAP conversion. I'll have to test it out.
Old Dec 6, 2009 | 03:04 PM
05RLS2's Avatar
It kind of makes you wonder how accurate the rest of the parameter readings are then on the gauge.
Old Dec 6, 2009 | 03:13 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Meh, mine always read the same.
Old Dec 13, 2009 | 01:53 PM
Talking
Casey,
Thanks for the suggestion. I switched it over to the boost reading the other day since I did the IAT2 conversion and so far it displays the boost properly. I will have to do some more checking, but it appears ok.
Thanks. Gene.
Old Dec 14, 2009 | 12:01 AM
ebristol's Avatar
They are both using the same sensor. The should be exactly the same.
Old Dec 14, 2009 | 12:55 AM
Originally Posted by Gene Culley
Casey,
Thanks. Gene.
any time. Glad it worked
Old Jan 4, 2010 | 02:00 AM
Buckweed's Avatar
you sure its reading in psi and not in bar?
Old Jan 4, 2010 | 02:53 AM
....yes. No gauge for the cobalt reads bars...its all translated to PSI
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
