Aeroforce Interceptor
Old Aug 4, 2008 | 08:16 PM
chad463's Avatar
Can this gauge read misfires? If so how do you do it?
Old Aug 4, 2008 | 08:36 PM
bolus's Avatar
From the manual: #44 total misfires
A1A-GM Supported Parameters (PID’S)
1. INTAKE AIR- Intake Air Temperature - **
2. COOLANT TEMP- Engine Coolant Temperature **
3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
4. TRANS TEMP 2- Trans temp for some vehicles made from ’94-’97.
4. RPM- engine Revolutions Per Minute **
5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
8. MAP SENSOR- Manifold Air Pressure (kPa) **
9. BOOST – Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
11. MILES PER HOUR- Miles Per Hour **
12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
13. KNOCK RETARD 2- used for KR value of ’94-’97 LT1’s and some 96/97 V8’s.
14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline
15. IGNITION ADVANCE- ignition timing advance
16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
17. SHORT TRIM B1-short term fuel trim bank#1
18. SHORT TRIM B2-short term fuel trim bank#2
19. LONG TRIM B1-long term fuel trim bank#1
20. LONG TRIM B2-long term fuel trim bank#2
21. OXYGEN SENSOR B1-O2 bank 1 sensor in millivolts
22. OXYGEN SENSOR B2-O2 bank 2 sensor in millivolts
23. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
24. BATTERY VOLTAGE- Alternator/battery output voltage **
25. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
26. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
27. PULSE WIDTH B2-injector Pulse Width for bank 2 (8 cylinder engines)
28. ENGINE LOAD- calculated Engine Load (0-100%) **
29. ENGINE OIL PRESSURE (some 8 cylinder engines) **
30. INTAKE AIR 2 – Intake Air Temp. downstream of intercooler (some supercharged applications such as the Cobalt
SS, Ion Redline).
31. TRANS TEMP AL- Allison transmission temp, Duramax and Workhorse
32. TORQUE CONVERTER SLIP AL- Allison transmission converter slip, Duramax and Workhorse
33. TQ TO TRANS AL- Engine torque delivered to trans, Duramax and Workhorse
34. INJECTOR RAIL PRESSURE DESIRED DM- Duramax
35. INJECTOR RAIL PRESSURE ACTUAL DM- Duramax
36. THROTTLE PCT DM- Throttle percentage- Duramax
37. THROTTLE VOLTS DM- Throttle sensor voltage- Duramax
38. FUEL LEVEL DM- Duramax
39. INJECTOR FLOW RATE DM- Duramax
40. Desired Turbo Vane Position- 2004+ Duramax
41. Actual Turbo Vane Position- 2004+ Duramax
42. Pilot Injector Pulse Width- pilot injector pulse width in msec. - Duramax
43. Main Injector Pulse Width- main injector pulse width in msec. - Duramax
44. Pilot Injector Timing- in degrees - Duramax
45. Main Injector Timing- in degrees - Duramax
46. Pilot Injector Fuel Rate- mm^3 - Duramax
47. Main Injector Fuel Rate- mm^3 - Duramax
48. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
49. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
50. HP 1- Calculated net horsepower for gasoline vehicles
51. HP 2- Calculated net horsepower for diesel vehicles
52. Analog 1 – analog input #1.
53. Analog 2 – analog input #2
44. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
45. BAROMETRIC PRESSURE- limited support on standard GM vehicles, DM support
Old Aug 4, 2008 | 08:43 PM
plus2ss's Avatar
The gauge will only show the missfiring cylinder if it sets a code, say a po301 if cylinder 1 is missfiring enough to set a code, or a po300 if multiple missfires. Other than that, i havent found data stream that shows actual missfires on the areoforce.
Old Aug 4, 2008 | 09:06 PM
chad463's Avatar
alright that all I needed to know. So you cant see it unless a code is thrown.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
