Aeroforce Interceptor Ques???
Old Apr 28, 2009 | 06:04 PM
HOT CARLS SS's Avatar
I own a SS interceptor guage for a SS/SC Cobalt....I have had the gauge for 1/2 yr or so...The gauge was working fine when on Sunday it wouldn't turn on (the display) it lights up blue but no numbers/readings...I unpluged the diagnostic plug waited for 2-5 min then plugged back in...The gauge comes on sometimes and not other times...I hear this is a common problem with the gauge?? Does anyone know how to fix this also is there another way beside HP TUNERS that can read IAT1/IAT2's ??? Ie: Dashawk??? not sure and how much are the other products to look at IAT?
Old Apr 28, 2009 | 06:42 PM
Zach06CobaltSC's Avatar
Your obd2 port runs off of a fuse in your engine bay thats labeled as ltr. Which is the same fuse that runs the cig. lighter infront of the shifter, aka directly under the radio. If that fuse goes out you might have some issues with your interceptor and or hptuners.
Make sure that fuse is working. Of the top of my head I believe its the 4th fuse on the very left hand side up from all the big fuses.
Old Apr 28, 2009 | 07:57 PM
Thanx for your help I will try that and post again....
Old Apr 28, 2009 | 09:16 PM
Angel's Avatar
Im having the same problem with one of my interceptors. I got the dual kit and one of them goes to the black screen and the blue leds come on once in a while and then it resets occassionally. Im going to contact the company to see if that one can be replaced because the other one hasnt missed a beat.
Old Apr 29, 2009 | 05:17 PM
Tried the fuse thing didn't work...I heard lotsa people have the same problem after awhile with the Aeroforce Interceptor Scan Gauge...????
Old Apr 29, 2009 | 08:41 PM
flash13brandon's Avatar
Try the Aerofoce website. They have forums.
Old Apr 29, 2009 | 08:44 PM
The Forum on the aeroforce website is not working?????
Old Apr 29, 2009 | 09:36 PM
well I take that back then lol. Have you tried to enter the maintenance mode or w/e they call it??
Old Apr 29, 2009 | 09:57 PM
How do you enter the maintance mode??? Thanx for the help..
Old Apr 29, 2009 | 10:35 PM
I can't exactly remember for sure. I believe you hold both buttons down for a few seconds when it starts to load up. The leds will light up and blink. Hold one of the buttons down until the picture clears up.
Old May 11, 2009 | 09:38 PM
Dre Day's Avatar
Yeah i think im having the same problem. It doesnt turn on when i turn on the car i have to diconnect it from the port then plug it back in for it to turn on. then it takes forever for it to turn off after i shut the engine off.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
