aeroforce interceptor scan gauge help?
Old Jul 8, 2009 | 01:37 PM
kyle1853's Avatar
ok so im not the best at electrical crap but does anyone know in english how to hook up the 3 mini wires to the car from the interceptor gauge?
Old Jul 8, 2009 | 02:33 PM
SCcobaltSS's Avatar
Are you hooking up any secondary 0-5v sensors for the aeroforce to display? If not I thought you hook the power to an ignition source and plug the OBDII plug in the port... someone correct me if I am wrong, its been years since I installed mine.
Old Jul 8, 2009 | 02:35 PM
kyle1853's Avatar
no just the gauge....no anologs
Old Jul 8, 2009 | 02:36 PM
ajm5036's Avatar
Thats correct. I just tapped into my boost gauge's power wire. And then just plug in the OBD and your set. Its so easy. Just wrap the other wires up.
Old Jul 8, 2009 | 02:40 PM
SCcobaltSS's Avatar
ok thanks! Thats what I thought.. I went all the way to the fuse box and did an add a fuse on the radio or something.. didnt want to mess with tapping wires.. but its your preference.
Old Jul 8, 2009 | 03:10 PM
kyle1853's Avatar
do you have to ground it to? i take it?,,,,,and i did just plug it into the obd2 but it wouldnt turn off lol .... and does it say ss when you start it up after original start up?
Old Jul 8, 2009 | 03:12 PM
SCcobaltSS's Avatar
no ground.. grounds through OBDII, turn the car off? lol, how did you power the gauge? and yes it does say SS
Old Jul 8, 2009 | 03:48 PM
kyle1853's Avatar
ok i get it now .....the obd2 on cobalts are always active thats why mine did not shut off... thats why they want you to pull the jumper plug on the back and use the alternate power wire..and the other to wires are for anolog 1 and 2 ...makes sense now
Old Jul 9, 2009 | 11:56 AM
Rydis's Avatar
I have a question about throttle %. Is it normal for it to flucuate without being touched and not be at 0 or 100%?
Mine at idle will fluctuate beteen 15-19 but wont ever got below 15, and at WOT, it is maxed at 89. is this normal?
Old Jul 9, 2009 | 12:15 PM
ShortStack's Avatar
the 15-1 at idle is normal..
max 89 though....?
Old Jul 9, 2009 | 08:45 PM
Rydis's Avatar
max 89 though....?
yeah, it wont go no higher then 89
Old Jul 9, 2009 | 09:10 PM
schamsy's Avatar
ditto... 89 is OK
Old Jul 9, 2009 | 09:11 PM
schamsy's Avatar
ditto... 89 is OK
Old Jul 11, 2009 | 09:55 AM
kyle1853's Avatar
thats gay ...so are cars could be faster...i think it might have something to do with our throttle body's being smaller that the actual sc inlet maybe
Old Jul 11, 2009 | 10:00 AM
Rydis's Avatar
I dont know...I just thought maybe my gauge was messed up, but others saying its normal so, maybe they are all like that.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
