af reading right??
Old Jan 10, 2011 | 12:40 PM
DEZZIE41's Avatar
Question af reading right??
at idel is goes from 14.2 to around 15.6
at normal driving 14.1 to 16.2 is this right/?
Old Jan 10, 2011 | 12:42 PM
CobaltVenomSS's Avatar
about the same what mine does... mut while driving i rarely hit 16.0 AFR..
Old Jan 10, 2011 | 12:43 PM
DEZZIE41's Avatar
it hardly hits it but that was the highest i saw it so its working fine then
Dirty25RS's Avatar
That sounds normal but, to make sure, floor it and see if it stabilizes between 10 & 11:1
Old Jan 10, 2011 | 12:45 PM
DEZZIE41's Avatar
ya it goes from 10 to like 11.5 i think it was
Old Jan 10, 2011 | 01:08 PM
InfraRedline's Avatar
Thats normal
Old Jan 10, 2011 | 10:03 PM
ziggity's Avatar
Install went good did it?
Old Jan 10, 2011 | 10:04 PM
DEZZIE41's Avatar
had wleded the bung in and had it all geared up in ten min
Old Jan 10, 2011 | 10:07 PM
srt-10's Avatar
All vehicals that run off of gasoline (doesnt matter what you drive) are programed to run at 14.7. The computer will make hundreds of adjustments every second to maintain that number. So it will give a little fuel or take some way, hence why it goes back and forth. When you go WOT it should be around 11.0 - 11.5. My truck does the same thing, it actualy goes to 12.0 - 12.5.
RaginChopsuey
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 28, 2015 02:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
