AFCO heat exchanger?
Old Mar 4, 2007 | 06:49 PM
dza39's Avatar
Does anyone know about the AFCO Pro dual pass heat exchangers and if hey will work or fit on out cars, if so is there anything else I would need to buy along with the heat exchanger. It says they fit directly on the Cobras and as we know the Cobras stock one fit on ours.
Old Mar 4, 2007 | 06:55 PM
BlilBT's Avatar
Whats the Size ie: Measurements?
Old Mar 4, 2007 | 07:28 PM
NGalaxyTimmyo's Avatar
You can use any heat exchanger and make it work. The problem is getting it to fit properly. What you need to do is figure out how much space you have to work with. Once you've got it mounted, all you need to do is disconnect one hose, put it into your second exchanger, buy another hose, hook it from your second exchanger to where you had the other hose. Well, theres more to it, but thats the quick version
Old Mar 4, 2007 | 09:02 PM
Ljavy17's Avatar
Post a pic.
Old Mar 4, 2007 | 09:50 PM
dza39's Avatar
Doesn't say the dinemsions all it says is its 28" long but here's the link anyway
http://www.rpmoutlet.com/03cobraheat.htm
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
