afr and a guage
Old Jan 27, 2009 | 04:32 PM
tdipowered's Avatar
afr and a guage
Ok so does the aeroforce interceptor show you afr? also what is a good afr reading? like below or above what number? im not really familiar with it but im gettin the ott stage 1 and meth so i want to know what i should be at incase i blow a fuse or i run out of meth i can tell by the guage....if the interceptor wont then i will just get an aem wideband. im open to better suggestions though. Knowledge is power
Old Jan 27, 2009 | 04:40 PM
ShortStack's Avatar
Interceptor will not.
you can get a wideband controller, which that will read through the interceptor, but the interceptor will not read afr itself. (it reads commanded AFR, not actual).
If you had meth and got a tune for it, and you ran out, you would start running lean.
low 11's is a good start for AFR.
Old Jan 27, 2009 | 04:56 PM
tdipowered's Avatar
so its better to get a wideband then?
yea thats what i read is that it would lean out...so thats why i want the afr guage just to keep an eye on it..
and ok so low 11s...is it bad if i go higher than that or lower than that..?
Old Jan 27, 2009 | 04:58 PM
ShortStack's Avatar
Lower is safer than higher (to a certain extent).
Higher normally yields more power. (to a certain extent)
Its okay if you hit the low tens, or mid 12s as long as when you notice it, you back down..
Old Jan 27, 2009 | 05:00 PM
tdipowered's Avatar
alrighty i get it now..if i start going high regularly i should probably tune it so it wont do that anymore right?
Old Jan 27, 2009 | 05:01 PM
ShortStack's Avatar
Depending on how you want the car to run...
something like that..yea..
Old Jan 27, 2009 | 05:03 PM
tdipowered's Avatar
safe and reliable..ill sacrifice some power so i dont push it to hard and ok thanks for all the help man.
ShortStack's Avatar
Yup.
Turbo Johnny
Feb 21, 2019 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
brett.higgins3
Sep 24, 2015 09:51 AM
Cptnslo
Sep 24, 2015 09:32 AM
SilverSS/SC
Oct 24, 2005 05:59 PM
