AFR ?? Help Rich AS hell????
I had my car tuned about 2 months ago(hp tuner tune ) car ran great until I ran a tank of 100 octane unleaded i ran through the whole tank then filled up with 93 afr was 11.5-11.9 now 10.0-10.5 wtf only other change is a kn typhoon intake no cel just confused at this point do i nned to reset the pcm or get it retuned ????
hmmm only thing I can think of is maybe the fuel trims relearned themselfs on the 100 octane and now they have to relearn them back. Run through this tank and then see what the next will do. Maybe someone else can chime in if they know something better.
Bump for you.
Bump for you.
Also, depending on what model cobalt the OP has, and provided I'm not wrong...pre 08 models don't have any sort of learn down feature or anything like that. If anything, this sounds completely ass backwards. I could possibly be wrong on this as well, but running 100 octane on a 93 tune would cause you to be rich as hell.
I would guess that you need your MAF retuned since you swapped the intake. I could see the car running slightly rich for a short bit after switching from 100 to 93 while the fuel trims adjust, but nomore than 100 miles.
2007 ss/sc
To add to the confusion the car is a 2007 ss/sc and was tuned on 93 ran the 100 beacause I added a h/e and for no apperant reason thought it was a good idea
took half the tank to bleed the air out of the system thought it would cause less issues ..
Turbo Johnny
Feb 21, 2019 09:41 AM
Cptnslo
Sep 24, 2015 09:32 AM
