After installing new clutch the pedal sticks to the floor
Old Dec 12, 2012 | 02:31 AM
zakmllr's Avatar
But only if I push it in all the way really hard. I bled the brake fluid (which was a B-word and a half). Any ideas what may be happening? I have a new throw out bearing as well.
Sent from my iPhone using CobaltSS
Old Dec 12, 2012 | 03:27 AM
bykryder83's Avatar
What throw out bearing did you use?
Old Dec 12, 2012 | 03:36 AM
bykryder83's Avatar
Also did you replace clutch master cylinder?
Old Dec 12, 2012 | 09:01 AM
mrbelvedere's Avatar
you need to vacum bleed it first to get the air out
Old Dec 12, 2012 | 10:00 AM
Smithkid21's Avatar
And you need to bleed the clutch fluid, not the brake fluid
Old Dec 12, 2012 | 10:18 AM
ZapFrog's Avatar
If you pop your hood, on the driver side of your engine bay there is a valve on the front of the transmission. You have to bleed the clutch instead of the brakes.
Old Dec 12, 2012 | 10:36 AM
zakmllr's Avatar
The clutch runs off the brake fluid from the master cylinder. And yes I did vacuum bleed it.
Old Dec 12, 2012 | 10:46 AM
ZapFrog's Avatar
Okay, Just making sure buddy.. I had terrible clutch problems in my previous balt. Did you check your Master cylinder? My old master cylinder kept breaking and kept coming through the firewall, make sure yours is securily attatched to the firewall behind the fuse box under the hood when you press on the clutch. If you press on the clutch and the master cylinder comes off the firewall a little bit, theres your problem.
Old Dec 12, 2012 | 10:47 AM
zakmllr's Avatar
Ok cool thanks ill check it right away.
Old Dec 12, 2012 | 01:46 PM
Omiotek's Avatar
a vacuum bleed i have found doesnt always take care of the problem 100%. i vacuum bleed to get some pedal feel and then do a 2 man manual bleed afterwards to ensure the airs out.
double check all your work. lines, distribution block and all that stuff..... its very easy to kink lines which will cause issues and such. if all that is good then your clutch isnt bled enough.
Old Dec 13, 2012 | 01:11 AM
insylem's Avatar
Manual bleeding these clutches SUCK ASS The bleed valve goes straight into the oil cooler
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
deviance
Nov 24, 2015 05:51 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
