Aftermarket intake manifold
Old Oct 16, 2008 | 12:04 PM
CobaltSS313's Avatar
I finally figured out where to get an aftermarket turbo manifold so the next thing on my list would obviously be an aftermarket intake manifold. I clearly can't use the stock intake manifold where the supercharger bolts on and i really dont want to use the intake manifold off of the 2.2 motor since its only made of plastic and id rather have 1 that is a little more than just plastic. I was wondering if anyone knew if anyone made one. Thanks for the help
Old Oct 16, 2008 | 12:06 PM
shutzero's Avatar
they sell adapter plates that bolt to your stock intake manifold so you can hook up your turbo piping to the stock intake manifold.
Old Oct 16, 2008 | 12:07 PM
Speedytec's Avatar
Saab 9-3 (2003+)??
Old Oct 16, 2008 | 12:08 PM
ShortStack's Avatar
hahn makes one...
http://www.turbosystem.com/ProjectVe...baltintake.htm
Awesome product...
The supercharger plate is another good idea, but if you would rather spend the money, get the hahn... As far as i know its the only one that has been made to work.
Old Oct 16, 2008 | 12:10 PM
Originally Posted by Speedytec
Saab 9-3 (2003+)??
I already tried it, even though the heads are similar the bolt patterns are different. My buddy works at a tranny shop n a Saab 9-3 came in with a blown motor. I got the Intake Manifold, Turbo Manifold, and turbo and it doesnt line up right to just bolt on.
Old Oct 16, 2008 | 12:11 PM
ShortStack's Avatar
The turbo manifold should work (maybe)
The intake probly wont fit..
Promise that hahn is the best you can get...
Cheaper alternative is the supercharger plate...
Old Oct 16, 2008 | 12:12 PM
Originally Posted by ShortStack
hahn makes one...
Awesome product...
Yah i saw hahn's i wasnt looking for something that expensive but if its all I can find I'll get it. What is the supercharger plate idea I dont think I know what your talking about.
Old Oct 16, 2008 | 12:13 PM
ShortStack's Avatar
https://www.cobaltss.net/forums/show...ighlight=plate
wish i didnt have to show ya.. i wanted it!! lol jk.. no $$
Old Oct 16, 2008 | 12:18 PM
wow thats sick is there a how-to on how to make that like thats awesome. I'd like to get my hands on the layout on how to make one.
Old Oct 16, 2008 | 01:14 PM
ShortStack's Avatar
Best bet is to take off the supercharger and take a look... get some measurments...
Old Oct 16, 2008 | 02:19 PM
Speedytec's Avatar
Strange... The LSJ head = Saab 9-3 head (2003+), so the bolt patterns on both manifolds should be absolutely identical.
Can you post a picture of these? Very curious..
Edit: Did a quick search here and found this 9-3 manifold pic in a thread:
Seems to fit perfectly on the LSJ head...
Old Oct 16, 2008 | 02:27 PM
ShortStack's Avatar
is that the exhaust manifold or the intake?
Looks like exhaust..
Old Oct 16, 2008 | 02:58 PM
ebristol's Avatar
Somebody makes a block off plate for the eaton where you basically gut your sc. I don't remember who.
Or if your real cheap just remove the by-pass blade on the supercharger.
If that blade is not there your supercharger will never create any boost. If it is not boosting it will not create as much heat. You will probably loose a little hp because it still requires effort to spin the blades but you will not loose near as much if you were boosting.
I don't recommend that as the perfect solution but I would like to see some one try just for fun! lol
Old Oct 16, 2008 | 03:10 PM
ShortStack's Avatar
lol..
did you look at the link i put up?
Thats awesome...
Old Oct 16, 2008 | 03:13 PM
BLAZIN07SS's Avatar
I'm too JDM for you
06blackg85ss aka Paul from NY found that the stock manifold blew up a few of the local turbo converted cobalts in NY. something to do with the airflow on cylinder 4. the hahn intake manifold apparently fixes that problem
Old Oct 16, 2008 | 03:21 PM
ShortStack's Avatar
Yes but the probability of that happening is higher with a turbo system pushing over 360-370..
The twin charge setup has been running for some time now at 350 hp... If your gonna run it at 320 hp (around stock turbo setup output) you will be fine... if you wanna run it higher, and dont wanna risk it, get hahn intake mani....
Old Oct 16, 2008 | 03:22 PM
ebristol's Avatar
lol..
Thats awesome...
Yup.
That is not the one I am talking about it.
There is another out there. You basically remove the snout of the Eaton and replace it with a block off plate. So it is just the housig of the M62 with no snout or rotors.
I CANT FIND IT!! grrr
Old Oct 16, 2008 | 03:28 PM
ShortStack's Avatar
OH!.. ok... actually that seems kinda cool...
What do you do with the belt in most cases?
i wanna a turbo kit as well... but am really not trying to spend 4500... Anyone have some suggestions?
Old Oct 16, 2008 | 04:06 PM
ebristol's Avatar
Switch to a belt system from an L61.
L61
LSJ
Dam. I still can't find that block off plate!
Old Oct 16, 2008 | 04:19 PM
ShortStack's Avatar
Ahhhhh alright.. i see
Thanks!
Old Oct 16, 2008 | 04:30 PM
ebristol's Avatar
Thanks!
Just so you know you will need to replace your alternator with one from a L61. The LSJ alternator only creates a charge spinning in one direction.
Old Oct 16, 2008 | 04:31 PM
ShortStack's Avatar
Oh **** shat... didnt know that..
Old Oct 16, 2008 | 04:43 PM
ebristol's Avatar
Ahh Hah! Found it!!
I still don't know who makes it....
Old Oct 16, 2008 | 04:45 PM
ShortStack's Avatar
dude thats awesome...
honestly... let me take some measurments... as long as theres nothing funky i can probly grind a piece of steel to taht size..
Old Oct 16, 2008 | 05:55 PM
Speedytec's Avatar
That looks very much like an aluminum Saab intake manifold with the LSJ bolt & breather hole pattern.
See the LSJ flange below...
