Air/fuel
Old Mar 10, 2010 | 09:46 AM
ACESSbalt's Avatar
Air/fuel
my afr is around 13.8-14.2 at WOT this is very bad right? what are some causes besides tuning?
Old Mar 10, 2010 | 09:48 AM
BLAZIN07SS's Avatar
I'm too JDM for you
yes that is very bad. it could be many things. what was your AFR before?
Old Mar 10, 2010 | 09:55 AM
MT0911's Avatar
not good.
Old Mar 10, 2010 | 10:02 AM
ACESSbalt's Avatar
cruising/idle its around 14.6-15.2
Old Mar 10, 2010 | 10:06 AM
~Mike~'s Avatar
So it's not getting much more rich when you mash on the throttle as compared to idle/cruise?
Old Mar 10, 2010 | 10:21 AM
Supercharged06's Avatar
i actually have a similar question regarding afr. i have a 2.8 pully and a fairly mild tune, when i go wot my afr comes down to like a 10.9-11.1 which i know is rich but its a safe tune bc i dont have cooling mods yet.
but when i go like 50-80% throttle and like 8-13psi my afr stays around 13.8 14.2 am i running to lean at non wot or is it ok bc im not makeing full power?
srry for the thread jack
Old Mar 10, 2010 | 10:25 AM
ACESSbalt's Avatar
correct
btw i have a 3.2 pulley on stock injectors with a tune (w/ 3 in intake and full exhaust)
could this cause my car to go into limp mode?
Old Mar 10, 2010 | 10:35 AM
Fonzi1289's Avatar
I dont see why.. Is it?
Old Mar 10, 2010 | 10:36 AM
BLAZIN07SS's Avatar
I'm too JDM for you
nah your okay, the car just isnt going into power enrichment yet because it doesnt need to
Originally Posted by ACESSbalt
correct
stock injectors are pretty much maxed on stock pulley. you could simply just not be flowing enough fuel
Old Mar 10, 2010 | 10:37 AM
ACESSbalt's Avatar
it goes into limp mode after about 20 min of driving and stay in it all day start it the next day and drives fine at cruising speeds
Old Mar 10, 2010 | 10:38 AM
nah your okay, the car just isnt going into power enrichment yet because it doesnt need tol
thanks blazin did the coils show up yet?
Old Mar 10, 2010 | 10:40 AM
ACESSbalt's Avatar
yea i thought about that as well, before i tried this set up i talked with a few people who ran/tuned for this set up before and said they had good luck with it, maybe my tune isnt up to par, idk i do have some dtcs ill post up after i run to the store to scan em
Old Mar 10, 2010 | 10:41 AM
BLAZIN07SS's Avatar
I'm too JDM for you
not yet, they should be here soon though
Old Mar 10, 2010 | 10:50 AM
skatin_boarding's Avatar
OP are you on the stock tune?
Old Mar 10, 2010 | 10:56 AM
Fonzi1289's Avatar
Yeah they r prolly maxed out and going static then.
Old Mar 10, 2010 | 10:58 AM
Zach06CobaltSC's Avatar
ACESSbalt - It's the tune man, even if the injectors are maxed you should still be seeing the correct afr down low. Is your maf dialed in? Are you running a maf only tune or ve only tune or a blend of both? Are you going into PE mode? Whats your PE Enable tps set at? If you need some tuning help let me know.
I would lower your PE enable tps, if you are 80% full throttle and not in PE then it's set to high in my opinion, especially for modded people.
Last edited by Zach06CobaltSC; Mar 10, 2010 at 10:58 AM. Reason: Automerged Doublepost
Old Mar 10, 2010 | 11:02 AM
rnjmur's Avatar
If possible you need to get a log of the car. Chances are you are maxing the injectors, but you shouldn't be maxing them until over 5K RPM. Under that the AFR should be fine. If it is lean all the time then your tune is definitatly out of whack. I don't suppose you have any way of putting up the tune so it can be looked at...
Old Mar 10, 2010 | 12:20 PM
megaman311's Avatar
ummm yeah, 10.9-11.1 is super lean!
Old Mar 10, 2010 | 01:03 PM
InfraRedline's Avatar
Uh no its not...
Old Mar 10, 2010 | 02:05 PM
rnjmur's Avatar
Definitely a good idea. I have PE kick in at about 5 psi no matter what the throttle % is.
Old Mar 10, 2010 | 02:16 PM
recklessactn's Avatar
Listen to this guy ^^^
Not this guy
Old Mar 10, 2010 | 02:20 PM
elite_Cyborg's Avatar
same here.
Old Mar 11, 2010 | 01:17 AM
Originally Posted by recklessactn
listen to this guy ^^^
not this guy
hahahahahahahahaha
Old Mar 11, 2010 | 09:38 AM
megaman311's Avatar
ha ha lol, i actually meant super rich not lean. i was reading another post and mistyped my words. sorry.
Old Mar 11, 2010 | 10:31 AM
Its all good I just thought the post was funny.
