AIS stage 1 meth kit install, boost port fitting.
Old Jan 4, 2012 | 09:37 PM
sick CCSS's Avatar
guys i got the AIS stage 1 trunk mount system, and it says to drill and tap into the lower intake manifold. do i have to do this> i thought it ran off vacume up by the actuator valve on the s/c. i really dont wanna drill and tap anything.
Old Jan 4, 2012 | 10:33 PM
Powell Race Parts's Avatar
buy a tb plate tapped 1/8 npt or before tb in the induction inlet hose
Old Jan 4, 2012 | 11:27 PM
sick CCSS's Avatar
alright so i already have a zzp tb spacer and it DOES have 2 ports, can i just use the one for the meth nozzel and the other port for the boost port fitting?
Old Jan 5, 2012 | 12:26 AM
shaman's Avatar
it may want you to thread the hobbs onto the engine. If it comes with a hose nipple, most any vac line should work
Old Jan 5, 2012 | 12:31 AM
sick CCSS's Avatar
nah nose hose nipples, just a brass plug, its short and just threads into something, then has a place to hook up their line on the end.
i think it should work, it would be getting vacume by putting it on the TB spacer along with the meth.
Old Jan 5, 2012 | 12:41 AM
rectorc08's Avatar
Plug it into the TB spacer. That's what it's meant for.
Old Jan 5, 2012 | 01:30 AM
mrbelvedere's Avatar
get a adapter with a nipple on it and screw it on the hobs switch then tap into the line going to the boost bypass solenoid then screw the meth nozzle into your tb spacer
the switch isent ment to go into the tb spacer
Last edited by mrbelvedere; Jan 5, 2012 at 01:30 AM. Reason: Automerged Doublepost
Old Jan 5, 2012 | 07:46 AM
sick CCSS's Avatar
alright guys thanks!
Old Jan 5, 2012 | 11:57 AM
sick CCSS's Avatar
anyone else?
Old Jan 5, 2012 | 03:18 PM
anyone else?
if you need anymore info i would suggest you call the company you got the kit from
Old Jan 7, 2012 | 08:19 PM
Xephirothx's Avatar
I have the kit set up like this: ... Meth switch is t-ed into the boost bypass line. And its worked fine since day one.. I can get a pic tomorrow during the day if anything .
Old Jan 8, 2012 | 12:51 AM
sick CCSS's Avatar
well i got the kit up and running, a pic would help others and i could compare mine to yours.
Old Jan 8, 2012 | 09:38 AM
getten gay in here
Old Jan 8, 2012 | 09:54 AM
Blowncavy's Avatar
Cause your in this thread
Spanky's Monkey
Mar 7, 2016 06:06 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
DocSvensk
Sep 27, 2015 02:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
yellowsupercharged06
Sep 17, 2015 04:40 PM
