Alans Block Party
Old Nov 2, 2014 | 09:24 AM
  #51
armcclure's Avatar
Yeah.. There's also a good reason I stayed with a 2.0. As long as you can hold the tq, rpm's make hp. I haven't peaked these cams yet but judging by the curve I would guess around 8500-9.
My plan is to keep tq moderate, around the 400-450 range, and use these cams (and the massive turbine housing) to hold it out. My first Dyno on these cams, peak tq was about 4800 and had only dropped 5ftlb by redline. With the current turbo, tq kept climbing very slowly till 6500 then leveled out.
So if I can maintain even 400wtq to just 8k, that's an easy 610whp.
Old Nov 2, 2014 | 10:55 AM
  #52
TStone's Avatar
Oh so now we're just shooting for numbers?
Old Nov 2, 2014 | 12:58 PM
  #53
nhanson's Avatar
Gotta love block parties!
Old Nov 2, 2014 | 03:18 PM
  #54
taintedred07's Avatar
We need more transmission options for builds like this
Old Nov 2, 2014 | 03:30 PM
  #55
TStone's Avatar
We call those progresssive controllers and boost ramps
Old Nov 2, 2014 | 03:35 PM
  #56
Terminator2's Avatar
The stock sleeve support and the clamping force of the head. The place that makes these for papaw uses this exact design in open deck honda sfwd cars pushing 900 wheel at over 40psi.
Non-intercooled Borg Warner s360et t4 .91ar with a 75 shot. 10.5-1 diamonds fully coated, ap rings, Molnar rods.
That's the basics.
Why non intercooled?
Old Nov 2, 2014 | 03:45 PM
  #57
TStone's Avatar
Why not?
Simple... cheaper... helps spool.....
Old Nov 2, 2014 | 03:49 PM
  #58
Originally Posted by TStone
Why not?
Where's the link????!?!?!?!?
Haha
  #59
Originally Posted by stealthy1ss
Way quicker spool and E85 takes care of the heat.
I disagree. A properly sized intercooler will not hinder spoil time enough to be noticed and E-85 will not overcome the IATs that will result from a high boost non intercooled setup. A non intercooled setup on e-85 will likely make about the same amount of power as an intercooled setup on 93 as the timing advance with both setups is likely to be about the same.
Old Nov 2, 2014 | 03:52 PM
  #60
TStone's Avatar
EVery little bit counts..... and alan gives about negative four craps about iat's. He's found his car runs better with a little hotter iat's. He always has other things to keep iat's in check....
soo.................................
Haha
If you want to have a mature conversation we can take this to PM's.
Old Nov 2, 2014 | 04:11 PM
  #61
I found the benefits of a good IC to far outweigh the disadvantages of the pressure drop across the core and the slightly slower spool (maybe 200 RPMs and a few extra hundreths of a second at most). Colder IATs are better especially on a 10.5:1 boosted car but even on a NA car. Even going from a stock IC to a better IC I found I could run 2-3* more timing vs the stock IC and I lost a half a second on my 60-100 times even with a muck larger than stock IC.
Old Nov 2, 2014 | 04:30 PM
  #62
armcclure's Avatar
Honestly I'm helping a friend move and don't have the time right now. But to sum I up I have gona far beyond our little realm of performance 4 bangers in setting up my system. Iat's level off at 120 running 22psi.
Old Nov 2, 2014 | 05:42 PM
  #63
mrbelvedere's Avatar
knock it off leave the gang mentality there
if you dig around and see how other non intercooled setups run and the temps they see you might suprised
Old Nov 2, 2014 | 08:33 PM
  #64
armcclure's Avatar
Exactly. Do some digging on non-intercooled blow thru carb turbo e85 setups. Manifold is cold to the touch after a pull, often has condensation buildup from the temp drop. I watched one make I think 1200whp a couple weekends ago. You could see the condensation on the mani from 10' away.
Just because most of my fuel is vaporizing after the temp sensor doesn't mean the exact same thing isn't happening.
You have to understand also that this is ONLY on e85/e98/meth.
There are plenty of gas cars that run non ic but they generally have to pull things back quite a bit.
Old Nov 2, 2014 | 09:23 PM
  #65
I can def see this being true for e85 since straight ethanol is about 4x btu/lb at stioch and additional fuel is required. And methanol is even better
Old Nov 3, 2014 | 09:25 AM
  #66
With an efficient turbo, reasonable boost levels and the inlet air source outside the 140* engine bay I can see it being feasible on E-85 or E-98.
Old Nov 3, 2014 | 11:17 AM
  #67
InfraRedline's Avatar
This is cool. These are the kinds of threads I like to see. Stuff that actually pushes this platform forward.
Old Nov 3, 2014 | 11:38 AM
  #68
yes definately ^
i'm in on this one.
Old Nov 3, 2014 | 12:28 PM
  #69
CrateEngineDepot's Avatar
IBMOB, but I guess I was too late.
Old Nov 5, 2014 | 08:42 AM
  #70
armcclure's Avatar
Lol what?
Old Nov 5, 2014 | 10:55 AM
  #71
IBMOB - In Before "Money Over Bitches" ???
Old Nov 7, 2014 | 10:04 AM
  #72
armcclure's Avatar
Who knows lol
Old Nov 7, 2014 | 10:07 AM
  #73
In Before Move Over Bitches?
Old Nov 7, 2014 | 03:19 PM
  #74
in before my ovaries burst?
Old Nov 7, 2014 | 03:35 PM
  #75
