Almost at 1500 miles!!???
i am almost at 1500 and i was told i would make full boost at that time. My question is do you feel a difference???? when you hit 1500 does it just reset or do you have to turn the car off first??
The car will make full boost when it is fully broken in, there is no reseting or turning off the car, i didnt notice a difference.
thats not what i was told and im not at full boost yet!! anyone else?????
i think im making like 10 or 11 pounds at the moment
usually goes to 12-13psi when u floor 2ndd gear and take it to redline and shift to 3rd...u should be able to see ur max boost in those 2 gears..u will go to 10psi before 4k and after 5k i beleive boost will rise to ur maxium...thats wat mine does
Hmmmmm
If I remember correctly off the dealer lot it was making its full boost at full throttle high rpms from the get go and we were driving it banging gears full throttle shifts with less than 30 miles on it for 45 minute drive home. After our stage 2 install at 75 miles it was also making its max of 15.5 or so on drive home full throttle high rpms as videotaped here: http://www.youtube.com/watch?v=fRh1dZgy4pw
Oh you found the boost switch within the woofer also did ya? LOL
i have been told by someone that i would believe that the boost only goes to 10.5 for the first 2000 miles, then after that it goes up to 12.5. or was it after 1000 miles? well one of the two anyway.
dude james it works at full boost from the factory I had ful 12.5PSI at my beckoning when I drove it off the lot with 10 miles on it
My buddy ben just got his SS/SC and with 300 miles on it, yes thats 3 0 0 miles we saw 12.5-13 on teh boost gauge. And yea, our "bump teh boost switch" was in the trunk in the middle of the sub woooooooooooferrrrrrr.
I don't think the computer has any real control over the boost as far as mileage is concerned.
Like someone posted, put your car in 2nd, floor it and take it to redline, and you should see a peak of 12.5. IF you don't, your engine just isn't quite broken in yet; it has nothing to do with the computer or "reseting". After a while everything should settle and you should see a full 12.5 lbs. of boost.
The car SHOULD be making full boost (12.5) right from the get-go, but mine didnt (10psi) until after about 1450mi and maybe coincidentally after my first hard launch. To be honest I dont remember the first time it went to 12.5, but I did notice a difference in power.
THREAD OF THE YEAR HAHAHAHAHAHAHAHAHAHAHAAH
yea a little elf comes out and says heres your 1500 and boom hes gonna kick you in the nuts , after that happens then you will know your at full boost , if this doesnt happen go to the dealer
Lol no you missed the thread of the year but it got deleted, i told someone on here that there is a boost activation switch in the trunk, and they made a thread about it, sadely it got deleted lol, all in good fun
