Almost seized the motor!
Old Oct 10, 2006 | 12:42 PM
Blown 4-banger's Avatar
Thumbs down Almost seized the motor!
Ok so I'm driving home from getting tuned, I get home and pop the hood to look at the header and I notice the engine compartment is FULL of oil! I'm thinkin I blew the motor or something! To my shock... THE ******* DIPSTICK POPPED OUT!!! WTF GM CAN"T YOU DESIGN A CAR TO KEEP ITS DIPSTICK IN!!!???!!!?? I don't know how much oil came out, but I'm sure if I had driven the car much further the motor would have seized
Old Oct 10, 2006 | 12:47 PM
DWK5150's Avatar
You arent the first person this has happened to.
Old Oct 10, 2006 | 12:49 PM
2K5SS/SC?'s Avatar
Wow! That sucks! Now we're going to have to come up with a dipstick mod! Would a thicker O-ring on the dipstick keep it in the tube better? <=No pun intended!
Old Oct 10, 2006 | 12:50 PM
That is so fucked up! I would sue them into oblivion if they didn't cover my car under warrenty regardless of mods!
Old Oct 10, 2006 | 12:51 PM
Yeah I think a bigger O-ring would work. I'm pissed though! We have to fix what those idiots at GM couldn't think of them selves!
Old Oct 10, 2006 | 12:58 PM
automobiliben's Avatar
Do a search, you aren't the first. Too much crankcass pressure...
Old Oct 10, 2006 | 01:00 PM
FraGmE's Avatar
glad I read this...gonna check mine make sure its ok.
Old Oct 10, 2006 | 01:04 PM
06blackg85ss's Avatar
mine did that once a few months ago... but I think it was more due to wheel hop, since it hasn't happened again.... two guys around here had that happen last week and ended up having holes in the pistons in cyl #4...
distillion's Avatar
is the caused by a pulley that is very small ie, 2.5-2.6?
Old Oct 10, 2006 | 01:05 PM
Originally Posted by Jim@Tagracecraft
Blowing the Dipstick out isn't a good thing
It somtimes means you are pressurizing the Crank case with boost
This is usually blow by ...boost going passed the rings
If t was me i would do a leak down test just to be sure.
We were done tuning so I wasn't hitting any boost. I was on my way home, just cruising in vaccum. I also checked under the hood before I left for home and the dip stick was in. It popped out at some point on the way home. Now I'm terrified to drive my car!
Old Oct 10, 2006 | 01:06 PM
that is not a good sign my friend... I"m sorry to say that... but if I were you I'd do a leakdown and compression test asap....
crossed over's Avatar
that is bullshit, if something like that happens to me and screws up my motor id make sure gm fixed it and some... if they wouldnt id take pics and post it everywhere... newspapers, internet, flyers etc. hahaha
Old Oct 10, 2006 | 01:10 PM
just remember :
#1 are pcv system can only handle so much boost stock (even says in the build book)
#2 YOUR CAR IS MODIFIED BEYOND STOCK LEVELS.. car is not meant for that not covered by gm
#3 running this type of power with no monitoring device I/e wideband/aeroforce is deadly for your motor.
Old Oct 10, 2006 | 01:12 PM
What if we drilled out the pcv opening to allow more air through?
Old Oct 10, 2006 | 01:13 PM
rickyw's Avatar
it sounds like gm couldnt keep in in the whole
jk
but in all seriousness that sucks i think they need to do a recall on all the cobalt ss/sc's on there wheel hope, clutch slipping, dipsticks, trannies, superchargers and what ever else. and put us all in the new cameros when they come out. its nice to dream isnt it. or atleast give us our money back so we can get a different car.
Old Oct 10, 2006 | 01:16 PM
i like my car! I don't want a different one! I don't think I could find another car that was as fast as mine AND get 30.9 mpg!!!
Old Oct 10, 2006 | 01:18 PM
2K5SS/SC?'s Avatar
GM did that in the build book in one of the steps. I think they pulled the valve cover off, cut the stock tube off, drilled the hole bigger, screwed in a barbed fitting, and put a filter on there. A catch can wouldn't be a bad idea either.
Old Oct 10, 2006 | 01:19 PM
maybe that should be my next mod?
Old Oct 10, 2006 | 01:30 PM
Catch can is the next thing for me over here... probably do that friday
Old Oct 10, 2006 | 01:33 PM
Edubs's Avatar
Anyone with the build book know what boost level is considered unsafe with the stock setup? Also, whenever any of you vets put a catch can on, might not be a bad idea to make it a how-to for everyone else. Take the questions out of the equation, if you know what I mean.
Old Oct 10, 2006 | 01:36 PM
Thats what I did when I installed my HE.
Old Oct 10, 2006 | 01:55 PM
silverSS's Avatar
happened to me one cold night when i had the 2.6 pulley on. luckily no oil came out.
called blow by
zip ties FTW
Old Oct 10, 2006 | 02:21 PM
2K5SS/SC?'s Avatar
Easy day. Pull off the hose from the backside of the camcover going to the intake tube. Mount catch-can where desired. Run hose from back of cam-cover to catch-can, and run another hose from catch-can to the intake. Done!
If I had a catch can myself I would have taken pictures, but I don't and my car is thousands of miles away. Hopefully that works for now though.
Old Oct 10, 2006 | 02:35 PM
Stilgar's Avatar
I changed my oil today, and my dipstick was fine(woohoo stock pulley!)
CTCOBALTSSS's Avatar
Nope. It happened to me at about 6,000rpms during my 1st of 3 dyno pulls.
There were drops of oil on my valve cover. I though I blew the motor and then come to find out the freaking dipstick poped out. It hasn't happened since. I just don't get it.
