Alright I got Codes out the ying yang.. Need help please.
Old Mar 23, 2013 | 03:17 PM
MrSlickSter06SS's Avatar
Unhappy Alright I got Codes out the ying yang.. Need help please.
Okay so the codes I have are:
P0101 - Mass air flow sensor - Which I just replaced last night.. But still showing the same code..
P0141 - Oxygen sensor - Which I am running a no cat down pipe so I assume thats why that is thrown..
P0300 - Multi miss fires.. Plugs were replaced 2 months ago..
P0325 - Knock sensor? This showed up today when I drove the car.. This came on after I just put the new MAF sensor on.
P0327 - Knock sensor (Circuit Low Input) this also showed up today after the MAF sensor install.
P1182 - Supercharger inlet pressure sensor, which I also replaced two months ago..
I replaced the MAF Sensor/the little sensor on top of the supercharger I believe its called the Barometric pressure sensor or something like that? New plugs because I was misfiring, which thats showing up to now.. Air to Fuel always drops to 10.0 even at a less than a quarter throttle, and doesn't create any power like I have no torque..? I am totally at a loss with this car.. Someone help me out please?
Old Mar 23, 2013 | 04:27 PM
Bump! No body..?
Old Mar 23, 2013 | 05:15 PM
Think all of this could be happening do to me having a bad throttle body? ive cleaned the throttle body alot, and had sprayed it down quit a bit maybe a messed the sensor up..?
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Dylan Johnson
Sep 30, 2015 08:57 AM
