Am i missing anything?
Old Jan 25, 2010 | 10:16 PM
elite_Cyborg's Avatar
ok well I'm about to start putting everything together and was wondering if i have all the parts to do so.
8-Rod Bolts
2-Cam Bolts
1-Harmonic Balancer Bolt
1-IM Gasket
1-Exhaust Gasket
1-Rear Man seal
Crank Shaft Bearings
Main Bearings
8-Flywheel Bolts
Water Pump Seal
Front Cover Gasket
Head Gasket
Main Bolts
Head Bolts
4-Sub Frame Bolts
Front Main seal
Liquid Gasket for lower girdle
Hows the list look?
Old Jan 25, 2010 | 11:22 PM
Supercharged Guy's Avatar
Everything looks pretty good man
Old Jan 26, 2010 | 04:25 AM
JapEatr's Avatar
South Central *********
crank pulley bolt?
Old Jan 26, 2010 | 04:29 AM
06_ion2's Avatar
you dropping the sub frame? those bolts too and girdle bolt's if your taking it off.
Old Jan 26, 2010 | 02:37 PM
Jazer's Avatar
I donno to the extent it is disassembled, but these come to mind
Front main seal
Crank/girdle bolts
Timing/Accesory chain cover gasket
Old Jan 26, 2010 | 02:43 PM
Front main seal
Crank/girdle bolts
Its completely Disassembled
so i need
4-Sub Frame Bolts
Front Main seal
DarrenGC
Dec 24, 2021 01:55 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
z28addiction
Sep 28, 2015 12:03 AM
Sean Cummings
Sep 11, 2015 09:35 PM
