Am i missing anything?
ok well I'm about to start putting everything together and was wondering if i have all the parts to do so.
8-Rod Bolts
2-Cam Bolts
1-Harmonic Balancer Bolt
1-IM Gasket
1-Exhaust Gasket
1-Rear Man seal
Crank Shaft Bearings
Main Bearings
8-Flywheel Bolts
Water Pump Seal
Front Cover Gasket
Head Gasket
Main Bolts
Head Bolts
4-Sub Frame Bolts
Front Main seal
Liquid Gasket for lower girdle
Hows the list look?
8-Rod Bolts
2-Cam Bolts
1-IM Gasket
1-Exhaust Gasket
1-Rear Man seal
Main Bearings
8-Flywheel Bolts
Water Pump Seal
Front Cover Gasket
Head Gasket
Main Bolts
Head Bolts
4-Sub Frame Bolts
Front Main seal
Hows the list look?
so i need
4-Sub Frame Bolts
Front Main seal
z28addiction
Sep 28, 2015 12:03 AM
