Another Air Box Modified
Old Sep 9, 2005 | 03:09 AM
myoshizawa819's Avatar
Did the air box mod tonight with the universal Spectre filter. Followed the instructions in the "how to" section with a few exceptions:
1. I did not find it necessary to use all three adapter rings. Using the largest two and leaving out the smallest seems to work fine, filter is on the flange inside the air box nice and snug.
2. Made a fairly good side hole for screw driver access. Why not, the hole just lets more air in!
3. Put the bottom of the airbox back on, but put a nice size hole in the center to allow air to easily enter the bottom element of the filter.
I reset the ECU, started her up and let her idle while I cleaned myself up a bit, took a 5 mile test drive. The sound is awesome and no CEL thus far.
One thing I'm wondering. Is the Spectre filter pre oiled from the factory? The package does not really say. I assumed it was because a heavy petrolium odor came out of the package when I opened it up, and the recharge oil is well sealed. Anybody know for sure?
To be continued tomorrow after a bit of shut eye.
Old Sep 9, 2005 | 09:34 AM
selfinfliction's Avatar
i don't think they are pre-oiled, but i wasn't 100% sure so i sprayed a very light coat over the filter. as cheap as the filters cost, i would guess that they are not pre-oiled
you should oil it a tad, and then leave the entire bottom off of it, the sound is so much better. i drove around th eblock with the bottom on, came back took it off and tested it again, and then decided to leave it off.
Old Sep 9, 2005 | 12:30 PM
Drove around for an hour this morning at various aggression levels and still no problems, it's nice to hear the blower whine
Another great mod from...
always wanted to use that guy
Old Sep 9, 2005 | 01:04 PM
lol.
Old Sep 10, 2005 | 11:21 AM
Went back in last night. Lightly oiled the filter and left the bottom off of the air box. Reset the ECU again and went cruising. Sounds sweet and still no CEL problems.
Old Sep 11, 2005 | 08:59 AM
OK, I take the freeway home from work and I work on 2nd shift so traffic is light to barely existent. The ramp I use to get on is long, straight, and slightly up hill. Got on last night and really opened her up for the first time with the new filter. Whamo...boost gage goes well past 10psi to 12-13psi where it belongs
Before changing the filter it would go up to about 10psi max. I was never sure how accurate the gage was so I never lost sleep over it. Accurate or not I now appear to be getting more boost with the filter replacement.
Old Sep 20, 2005 | 04:36 PM
cobaltboy69's Avatar
What is the filter mod....just a K&N filter or a new intake??....post a link plz i'd like to look into it...
Thx
Old Sep 20, 2005 | 08:19 PM
The mod posted in the "How To" section of this forum. Same filter and everything.
Old Sep 29, 2005 | 02:38 AM
CobaltSS422's Avatar
It's a lean code.. I took my car to the dealer and they told me it came on while i was speeding at 68mph... lol i was on the thruway that the spped limit was 65mph and he said it was running lean or somethin
Old Sep 29, 2005 | 02:42 PM
dimeo09's Avatar
i got a CEL too, would that code cause any problems.. or is it no big deal and the pcm will compensate for the lean mixture....?
Old Sep 29, 2005 | 04:15 PM
Wolfman's Avatar
Im not sure if I should do it or not.
Old Sep 29, 2005 | 08:02 PM
Jmc007's Avatar
Wolfman I suggest you strongly to wait to buy a good CAI which as been previsouly dyno test. I am one of the few one who dyno the car with and without the airbox mod, and this mod have cause a HP loss.
Old Sep 29, 2005 | 11:27 PM
dimeo09's Avatar
what the difference between what weve done and a cai intake....... nothing except the your paying 220 dollars for something that looks better
Old Sep 29, 2005 | 11:56 PM
NGalaxyTimmyo's Avatar
Yea, I'm kinda confused here....
That would be the third car I've heard dyno'd and getting a loss with the airbox mod. Anyone have a reason for this?
Old Sep 30, 2005 | 07:34 PM
dimeo09's Avatar
i dont think its even possible to have a lose of HP when your simpley adding a less restrictive cone filter...
Old Oct 1, 2005 | 02:05 PM
NJBLUESS's Avatar
It's not, also there is no difference in the mod or a CAI. If you do get a PO171(system lean), then it IS A GOOD thing. You are now drawing in more air! You get this code becuase the PCM has seen a difference in the amount of air entering the engine and is adding more fuel to compansate, which will send your fuel trim levels past their threshold. You say that you reset the PCM by disconnecting the battery, Wrong, won't always work. The PCM does have memory and back-up capasitors to prevent a loss of memory. The proper way to reset the fuel trims is with a Tech 2 scanner. Someone said they lost HP after this mod on a dyno, I do not believe the trims were reset properly and even if they were it was stated the drove around the block. It will take more than that to relearn there values. I have installed a K+N conical filter in mine (part# RF-1025) and left the bottom off with no problems. Oh yeah, the turbulance theory is just a theory, you did not change the distance of the inlet to MAF sensor and nobody has seen the airflow inside.
Old Oct 2, 2005 | 09:46 AM
Jmc007's Avatar
You don't THINK that it's not possible to lose HP with the airbox mod, but the real question is: Have you DYNO it ????
Old Oct 2, 2005 | 07:13 PM
NJBLUESS's Avatar
No, I did not dyno my car, but my point is that in my opinion the PCM has not adapted to the modification yet. Others are claiming HP increases WITH dyno results. I'm just saying it should be looked into further.
Old Oct 2, 2005 | 08:22 PM
Jmc007's Avatar
We got TWO SS/SC dynoed with a loss of HP with the K&N conical RU-2710 filter, that was not based on opinions ...
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
