Another cobra haet exchanger thread!
Ok so a buddy of mine is going to sell me his 04 cobra heat exchanger for $20 so its a steal so i wanna get it im just a little afrade of the install i heard it is easy and simple to do, i have seen the how to and diffrent pic's of it being done but if any one can show me more pic's of what needs to be done and how to route the hoses it will be a great help also how to bleed the system so i have no air pockets thanks!!!
I used the BWoody brackets, although for what they are they are about 50 dollars overpriced, but they made mounting brainless....
I just took the line off that runs from the stock intercooler to the pump. I put a passthrough fitting in that line, attatched a house to it and ran it to the top of the heat exchanger inlet. Then I ran a house from the bottom heat exchanger outlet back to the pump. It took me less than an hour to install.
As for bleading the system, I took out the passenger side headlight, removed the bleeder screw on top of the factory intercooler, and filled the system with dex until coolent came out of the bleeer screw. I reinstalled all of that and am not slowly adding coolent to the system as needed through the fill tube. Some say it takes several weeks to get all the air out of the system, we shall see. I am thinking of going to the junk yard and getting a coolent overflow tank and plumbing that, ala option b, but am unsure how to plumb option b without the dual pass option installed. Hopefully someone can chime in on how to do that, as it would be less than ten dollars in parts to add that if I can find a resivoiur at a boneyard that fits.
n20saturn
Sep 30, 2015 12:26 AM
