ran into trouble taking out stock exhaust
well im trying to take it out with out cutting it and i unbolted the shocks. lowered the crossmember but it wont go down far enough to slide it out. do i got to take of the brake lines?
well i know people have done it before. and like i said i dont want to cut it. i just need the crossmember to be lower just a little bit more and i can wiggle it out
Dude just cut the goddamn thing. Work smart, not hard. If you need to use it right away just go out and buy a 2-1/4 band clamp until you can get it re-welded. Hell i'm not even going to bother getting mine rewelded. I've been rocking the clamp and it is just fine.
Apparently half this thread completely ignored what the guy said about not wanting to cut it. He's not going to cut it. He's swapping it with someone.
Reading > Those who said cut it
Also to the op if you do end up having to cut it... It will cost you $10 bucks to get it weled at damn near any exhaust shop
Good luck passing NY state inspection with a clamp on your exhaust... Next time you get it inspected its going to fail for exhaust leak.... trust me it happened to me when I had my CRX in NY, andit also happened here in VA with the balt when I clamped my exhaust, but yes it is a great temporay fix...
haha i ****** cut that bitch off.. if i could jack my car like 2 -4 inches higher i could of got it out in one piece. just needed the cross member to go down like one inch.
camaromanss1992
10-01-2015 10:51 PM
09BlkCrusader
09-09-2015 04:47 PM
