Another Down Cobalt
i blew mine 300 miles after my warr. .....................do u still have the stock cat........mine melted on my way 2 florida......................had 2 gut it in an autozone parking lot in TN...........lol.................but then about 3k after that BAM same thing urs is doing......mine was the first cyl. rings........they went bad and made big groves in the cyl. wall.......so now i have 2 re sleeve it 2..........
he was 2.6 pullied and had the cobalt addiction h/e
lol, he blew the mtor just doing a 1st through 3rd pull about half way through third pop
yeah i kinda had to laugh inside, becuase he has like destroyed the car, in order he blew his piston, broke his axle, broke the stg2 axles, blew his motor, got a new motor and blew his tranny
are my mods so i was good everywhere else..maybe the tune also who knows?!
dependson the dyno man, and in the end there just numbers. Go to the track and figure out what it does. I have seen 2.5 pullied cars dyno 230's and i have seen stg2 cars dyno 245. Then you see them at the track and see who's running faster and it becomes obvious that those numbers meant nothing at all.
egt, exhaust gas temperature.
tells you how hot the combustion charge is getting. id bet money that it barfed number 4 due to this. i freak when i see it at 1450
build i had in mind for mine. if i have it long enough
272 cams
10.0:1 c/r, swain coated pistons
arp head studs.
arp main studs
arp rod bolts
p/p job on the head
custom longtube header
stock blower.
cometic head gasket. or custom sce.
272 cams
arp head studs.
arp main studs
arp rod bolts
p/p job on the head
stock blower.
