Another Duel Pass Question...
Old Sep 24, 2007 | 07:26 PM
XbandiniX's Avatar
I was wondering if anyone knew actually how much of a Intake temp decrease I could expect to see after the install. And how much more cooling you get out of Option B.
Old Sep 25, 2007 | 02:26 AM
LopsidedJester's Avatar
i haven't done a comparison of before and after, but with my dual pass option B i see 20-30 degrees cruising straight on the highway. I think what really matters is full throttle temps and i haven't seen mine go any higher than 140 degrees WOT up to 120 mph on an 80 degree night.
Old Sep 26, 2007 | 03:54 PM
ridemlow03's Avatar
do you have to get the the dual pass kit in order to put the option b surge tank in?? also is 140 high???
Old Sep 26, 2007 | 06:14 PM
Yes, you can do option B to your stock setup if you feel like it, the dual pass just allows the aftercooler to work more efficiently. Option B mainly allows more heat latency which keeps your car cooler for slightly longer and delays heat soaking.
Also, over 160 is something to really start worrying about, 140 for a 2.9" pulley and stock H/E seems alright in my eyes, but i haven't seen it that high as of late and that was when it would peak WOT around 115-125 right before i shut it down. Our superchargers are heat factories.
Old Sep 26, 2007 | 08:40 PM
FryLoch's Avatar
How does the duel pass work? I know it's the intercoller plate but how does it help if you just use the same stock reservoir? also how do you run to lines, do you just tape a hole in the tank?
Old Sep 26, 2007 | 08:47 PM
the dual pass allows the single in and single out 4 pass to change into a single input and dual output hose configuration, changing it to a 2 pass in the aftercooler. the dual output hoses are T'd together and the stock reservoir still runs with 1 in and 1 out, so no tapping needed.
Old Sep 26, 2007 | 08:49 PM
FryLoch's Avatar
the dual pass allows the single in and single out 4 pass to change into a dual input and single output hose configuration, changing it to a 2 pass in the aftercooler. the dual input hoses are T'd together and the stock reservoir still runs with 1 in and 1 out, so no tapping needed.
Why would that help? seems like it would flow less coolant.
Old Sep 26, 2007 | 08:53 PM
in a 4 pass setup, cool coolant heats up through all 4 passes. in a 2 pass, cool coolant starts on the outside passes and then the coolant makes a second pass on the inside and goes back out the hose.
in the 4 pass, coolant may heat up so much by the 3rd or 4th pass that it can't help cooling anymore, so a dual pass allows a smaller routing of cool coolant. In the dual pass, the coolant may flow slightly slower through the dual pass due to mass flow restrictions, but it still allows for more efficient cooling (mainly more even spread in exchanging heat than the large amounts of cooling on the first pass and less cooling further on with a 4 pass). A larger aftercooler pump may also allow better cooling with quicker flow in the dual pass.
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
goaliemo
Sep 28, 2015 01:37 PM
