Another TVS thread
Old Apr 26, 2008 | 10:33 PM
ralliartist's Avatar
Another TVS thread
Well, I can't say where this is, and I can't say who it is, or who told me. BUT, someone has already reached the limits of the TVS without meth injection.
360whp and 297wtq. on the 2.75" pulley. Timing was at about 16 degrees and AFR in the high 11's. With 2 h/e's and dual pass with opt. B, the intake temps got up to about 180 degrees. This is also with a built head. Onlything stock in the head is the cams. But the head is ported out, bates oversized valves and springs. He is also revving to 8000rpms. He has the I/H/E stuff as well.
Now, although the power level is not quite what a lot of us thought it to be, I'm not really too discouraged. This is about the power level of where I want. If I want to go any faster, I'll spray it. But 350hp and 300tq is plenty enough power for me. I'll bet with some meth injection, the numbers would be a little better also.
So thoughts?? Opinions?? Flaming??
Just to add to this, the guy that tuned him has a stock engine, but I/H/E with 2.8 pulley, dual pass opt. B, meth injection, tuning, and a 75 shot and still got beat by the TVS car. He said he hung right behind him till about 75mph and then the TVS car just pulled away like crazy. Pretty cool.
Old Apr 26, 2008 | 10:36 PM
UmeNNis's Avatar
thats more than enough for me!
Raven SS's Avatar
how did he max it out?
Old Apr 26, 2008 | 10:37 PM
Originally Posted by UmeNNis
I like it. I love it. I.... got it at Ross?
what?
you tell me. any lower of a pulley and the engine would have destroyed itself. Heat was getting up there!
Last edited by ralliartist; Apr 26, 2008 at 10:37 PM. Reason: Automerged Doublepost
G85 SS's Avatar
Those numbers look good to me. I'd like to get a TVS charger but I don't have $2500 for one.
With that blower would I have to swap internals or no? I wouldn't be running a 2.75, I would probably stay with a 2.9 on it. Any ideas?
M-Dub's Avatar
That seems pretty crappy for a 2500 blower!
Old Apr 26, 2008 | 10:38 PM
Sunburst_SS's Avatar
I dunno, I'm happy with mine....300 wheel and 260+ tq is plenty of fun in my car....I'm sure 360 wheel is crazy
Old Apr 26, 2008 | 10:39 PM
Raven SS's Avatar
methanol he'll be fine...i dont think thats the "limit" of the tvs
Old Apr 26, 2008 | 10:41 PM
Like I said, it's more than enough power and I think the money for it is well worth it.
M-Dub's Avatar
A turbo would get you that and more with much more reliablilty and efficiency!
it is in my opintion.......the blower makes good power, a nice powerband, builds boost quick!!! Makes for a happy driver
Old Apr 26, 2008 | 10:44 PM
obviously with meth he'd be able to make better numbers and probably even go with a tad smaller pulley. BUT, those temps are getting pretty scary without meth. I'd say he's at the limit.
this is a true statement. But I'd be perfectly fine with the tvs. I don't need a rediculously built 10 sec cobalt. I'm sure with slicks, you could get high 11's with the tvs. Which is what I want and WILL achieve.
Last edited by ralliartist; Apr 26, 2008 at 10:44 PM. Reason: Automerged Doublepost
ok, yes a turbo is more efficient......but how do you say they are more reliable??
A turbo has alot more required to maintain and keep up......Not to mention converting the car from blower to snail requires a bit more knowledge then upgrading a blower....
Different strokes.....but let's not turn this into another turbo vs. charger thread
x2, I'll probably be getting one as soon as i return from my deployment.
Old Apr 26, 2008 | 10:47 PM
M-Dub's Avatar
Oh, Im not going that way! believe me I'm all for the TVS's... but if they are only able to produce 350/300 a small quick spoolin' snail will get that!
I updated the first post with a short race story from the guy that tuned him.
Old Apr 26, 2008 | 10:48 PM
KillerBee's Avatar
damn ZZPs Twincharge kit is pushings 387 whp
Old Apr 26, 2008 | 10:50 PM
Rodimus_Prime's Avatar
I think thats plenty enough power
Old Apr 26, 2008 | 10:53 PM
obviously there are going to be other options that will make more power. But if a straight blower swap is what you want and plenty of power, then this is a very good solution.
Old Apr 26, 2008 | 11:00 PM
WSFrazier's Avatar
I wouldn't say it was maxed out. I'm sure someone will toss a 2.5 or lower ring on it. Meth will definitely make it possible. Plus cams, 400whp will most likely be seen with this blower, probably on Witt's car.
Old Apr 26, 2008 | 11:06 PM
true, but i'd say it's maxed with a 2.75 without meth. With meth, you could squeeze out a bit more. 400 sounds about right with meth and a 2.5 or something like that. Remember, this guy was on a built head also. I doubt MOST people will even see numbers this high.
Old Apr 26, 2008 | 11:23 PM
Pyros777's Avatar
Is it using the stock cam profile? I've always been under the impression that you'd need a different set of cams to make use of 8k rpms.
Also does the dyno that was used typically give over or under rated numbers?
thanks
Old Apr 26, 2008 | 11:44 PM
INFE's Avatar
thats about the numbers where i want to be but, 180 degree IATs is deff not reliable and its pretty damn scary if u ask me. Meth is def in order there.
Old Apr 26, 2008 | 11:50 PM
RuSSo-29's Avatar
Mustang Dyno or Dynojet?
Old Apr 27, 2008 | 01:04 AM
Darkmanx's Avatar
so when is this person going to say who he or she is?
