Any one have this happen
Old Dec 11, 2005 | 02:35 PM
CobaltSS05's Avatar
I have had my SS for about 5 months now i have 6700 miles on it. I have had the car in the shop 4 times now for the samething CEl light and they say the dip stick and or dip stick tube is being pushed out of the engine. Now this time i have it in there and the tell me its because i cut off part of my airbox (was going to do air box mod but took back the K&N and got my money back). They told me its because it is sucking in too much air causing this to happen. I call BS it sounds liek blow by to me how else would the air get to the bottom part of the engine with out goign by the rings? I just think they have no idea whats wrong with the car so they wanan blame me for the whole thing it sounds like i got a hold of a lemon. If anyone had any ideas let me know. Thinking about trading.
Old Dec 11, 2005 | 02:39 PM
Chevypowered's Avatar
What code are you throwing?? If its the lean code then its probably from cutting the airbox.
Old Dec 11, 2005 | 02:42 PM
CobaltSS05's Avatar
how would cutting the airbox cause the the dipstick to do that.
Old Dec 11, 2005 | 02:44 PM
No i was saying if its the lean code that it could be the effect of cutting the air box. I don't know about the dip stick. never of heard that happening before, perhaps its a presure build up in the oil pan that cause the dip stick to be pushed out??? what code are you throwing so we can have a better idea of what is happening
Old Dec 11, 2005 | 02:49 PM
CobaltSS05's Avatar
it is the lean code there are 2 service # PIP3210E and PPI3492A
Old Dec 11, 2005 | 03:44 PM
dirtySSout's Avatar
Ive never had that problem. thats wierd. Sounds like they are jerking u around.
Old Dec 11, 2005 | 05:37 PM
CobaltSS05's Avatar
yeah it feel like they are jerking me around. Anyone have a glue on what to do with this?
Old Dec 11, 2005 | 05:39 PM
keeper51's Avatar
i dunno either, seems i'm getting jerked around. My check engine light keeps coming on and going off every other day and I took it in last week, they told me something about computer not recognizing me using my clutch to shift gears, they cleared the codes but check engine light came on again the next day and stays on, anybody else having problems with the check engine light cause it's quie annoying.
Old Dec 11, 2005 | 05:46 PM
BowTieCobaltSSSC's Avatar
My CEL comes and goes also with the stock air box and stock filter ( no mods ) P0171 lean,I also get the same thing with the K&N CAI .so i'm not convinced the after market intakes have any thing to do with the CEL P0171 . Mine set the code 2 times prior to getting my CAI .I have the Stock Box on for winter and the dealer replaced the MAF sensor and still getting a CEL .
SO GM what ya gonna do ??
Old Dec 11, 2005 | 05:49 PM
Doc's Avatar
Doc
Lil Blue SC has that same thing happen. He has the K&N intake. He has oil all over his engine compartment yesterday and today....He doesn't get any CEL to my knowledge. He is a tech for GM, actually subaru...send him a pm and double check...
Old Dec 11, 2005 | 05:50 PM
Cobalt_Supercharged's Avatar
I wonder if it is a bad/plugged PCV. That would cause the pressure to build in the crank case.
Old Dec 11, 2005 | 06:18 PM
CobaltSS05's Avatar
sounds like GM needs to make a freakin recall on this car.
Old Dec 11, 2005 | 06:21 PM
Lil Blue SC's Avatar
YEA it happen to be the dip stick gets pushed up and oil goes all over the place... Anyone have an idea how to eliminate..????????????
Old Dec 11, 2005 | 06:37 PM
CobaltSS05's Avatar
oh yeah the only part i cut of fthe air boz was the part that look like a snorkel how could that suck in more air? and they want to charge me liwk 400 bucks to fix.
Old Dec 11, 2005 | 09:41 PM
97cavie24ls's Avatar
my buddies redline had the dipstick come out on his , no idea why it happened either
Old Dec 12, 2005 | 09:34 AM
SS_SC_Cobalt's Avatar
its called positive boost....boosting the engine makes crankcase pressure positive...pushing the dip out
Old Dec 12, 2005 | 09:38 AM
wesmanw02's Avatar
Any idea what needs to be done to correct the issue?? Screw in dipstick maybe??
Old Dec 12, 2005 | 09:41 AM
Just tape that thing on, wrap it a few times problem solved
Old Dec 12, 2005 | 09:43 AM
BullDog71ss's Avatar
It's the PCV (Positive crankcase ventilation) valves' job to release crank pressure from the crank case without letting oil excape the pan. Sounds like it could be malfunctioning, as Cobalt_Supercharged has already stated.
Old Dec 12, 2005 | 09:51 AM
wes_woodbridge_ss's Avatar
I was runnin a lean code for the first few months that i had my 05 SS/SC the dealer blammed me at first, said i was hittin the red line out of gear. I called their bs so i took it back and they found a recall on the stock filter. The car came with a restrictive filter and had to be changed to a high-flow from GM. Cost me nuthin all warranty. The car hasnt had a code since.
Old Dec 12, 2005 | 11:25 AM
dazednconfused75's Avatar
There's a video floating around of a Red Line on a dyno when the dipstick pops out.
Old Dec 12, 2005 | 10:03 PM
CobaltSS05's Avatar
any guys with a CAI wanna get rid of ur stock air box ?
Old Dec 12, 2005 | 10:32 PM
J.D.'s Avatar
These guys are dead-on your problem. Not likely that it's blow-by, the PCV should still handle that, and you would find gas in the oil pan. I say tell em to check/replace the PCV. just my .02
Old Dec 13, 2005 | 06:11 PM
Yea ill sell ya mine....
Old Dec 15, 2005 | 10:19 AM
num482's Avatar
check the pcv. IF that doesnt work pull the oil cap and replace it with a breather
