Any S/C SS's try a lightweight crank pulley yet? Like this one?
Old Apr 8, 2006 | 11:36 AM
Bad06SS's Avatar
Hey guys. I'm sure there are other companies that offer a lightweight pulley, I just happend to choose this one. Has anyone tried a lightweight pulley on there 2.0? If so, how'd you like it? Does it rev alot quicker like it says? Where did you find a smaller accessory belt? If not, what are everyone's thoughts?Supposedly it frees up some horsepower and helps the engine rev alot faster. This one is from rsm racing.
Yes, I did a search, the only thing that came up was that everyone was unsure if it would work.
Old Apr 8, 2006 | 12:01 PM
zinner's Avatar
Moderator Alumni
Make sure it's not an underdrive crank pulley.
Old Apr 8, 2006 | 02:00 PM
2K5SS/SC?'s Avatar
Overdrive crank pulley like Jackson Racing ones would be nice though!
Old Apr 8, 2006 | 05:19 PM
03gobluecobra's Avatar
You shouldn't need a smaller belt. If you do, it won't work. In that case it would actually make the supercharger spin slower, which you don't want at all. If it's the same size, only lighter, I don't think it will make much of a difference. Your money would be better spent elsewhere. If it's bigger, it will spin the supercharger faster, and give you more boost. Basically the same as an upper pulley, but it will also spend more hp on driving the rest of the accessory belt.
Old Apr 9, 2006 | 08:54 AM
Jmc007's Avatar
First a lighter crank pulley will allow the engine to spin faster. Second there is not more clearance around the crank pulley to install a bigegr one.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
