? on any stage kit
Old Mar 6, 2006 | 07:46 PM
boostedss26's Avatar
? on any stage kit
The Gm stage kit comes with an ecu reflash,2.8 pulley and 42.5 injectors. i have a 2.8 and the injectrs. Now can i just go to my dealership for a reflash and call it a stage 2?
Old Mar 6, 2006 | 07:48 PM
plyboy-illest's Avatar
not too sure since its not the gm kit thats in the car they might give you some problems
Old Mar 6, 2006 | 07:49 PM
max_boost's Avatar
You can call it whatever you want, but the Stage 2 kit pulley will be closer to 3.0 and I doubt the dealer will just reflash the ecu without you buying the actuall kit.
Old Mar 6, 2006 | 07:53 PM
My buddy is a tech their and he will do it but neither of us are sure if it's the same thing. i don't see what the difference is except for its alot cheaper.
Old Mar 6, 2006 | 08:01 PM
max_boost's Avatar
Well it's your car, you can call it what ever you want. The reflash is the most important thing anyway. a pulley is a pulley and will work just as good as any other, same for injectors.
Old Mar 6, 2006 | 08:35 PM
zinner's Avatar
Moderator Alumni
The flash/calibration requires a serial number and your vin number it install according to some of the other techs on the board. Leads me to believe your tech friend can't just flash your car for free.
But if he can make sure to report back cause that would kick ass.
Old Mar 6, 2006 | 09:28 PM
iso's Avatar
iso
the stage 2 pulley is a little biger than 3". the reason for this is believed to be because the stage 2 reflash is going to raise the rev limiter to 7k and anything smaller than a 3" pulley will overrev the supercharger at 7k rpms.
Old Mar 6, 2006 | 09:59 PM
So should i just buy a 3" pulley? or the whole kit?
Old Mar 6, 2006 | 10:00 PM
In the intense kit and the psi kit both have a 2.8. I'm a little confused on why they have the smaller pulley and not have a problem.
Old Mar 6, 2006 | 10:05 PM
patathSS's Avatar
6.5k redline, no worry of overspinning the blower.
Old Mar 6, 2006 | 10:09 PM
JPK's Avatar
JPK
Because they are redlining at 6450 not 7K. Faster engine revs = faster s/c revs.
However......on the RL forums, it was discussed that the tests on the SC is CONTINUOUS rpm's and also those are the numbers for the the 4th gen M62. Our cars have the 5th gen which is good up to 16K continuous rpm.
Old Mar 6, 2006 | 10:14 PM
i hope your right. I just bought this pulley from sfphq i figured since they made it it was safe.
Old Mar 6, 2006 | 10:34 PM
BlAckOnBLaCK's Avatar
As long as you don't drive your car at a steady 7K rpms, I really wouldn't worry about it. How long do you keep it at that mark.......a second. Don't think that is a problem.
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
