Any thoughts on this?
Old Apr 30, 2007 | 07:21 PM
alaskacobalt's Avatar
Stage #6: 2.5 ZZP Interchangeable Pulley system , 2 step colder ngk IRIDIUM spark plugs , GM shortened belt , ZZP Adjustable Tensioner , 60# Siemens Injectors , Injector Wiring Harness, CA Methenol Kit , CA Heat Exchanger Kit, CA Dual Pass Intercooler Plate, CA nitrous controller , Stage #6 Retune ... Est. 90 Hp / 100 TQ over stock - 21psi boost - Higher yield with nitrous installed
Stage #6 Your Price: $1849.99 USD + *Free Shipping*
I just saw this at Cobalt-Addiction.com. Anyone have anything good or bad to say on it. I am looking to get it, but I want to know if it is worth it or if you know of a better setup. I currently have stage 2 GM with Fujita intake and that's it so far, but I figure I need a lot more power so that these damn 350Z's will leave me the hell alone! ;0
Old Apr 30, 2007 | 07:42 PM
Rodimus_Prime's Avatar
id move up to a 2.6 or 2.7 pulley, 2.5s are just too much heat to be reliable, consider also getting a co2/nitrous intercooler sprayer, your going to need it
Old Apr 30, 2007 | 08:39 PM
Mattman6's Avatar
have fun blowing up your engine if you get that setup, you will need exhaust mods also.
Old Apr 30, 2007 | 09:49 PM
Ahhh, that's the information that I need. But please explain why this would blow up my engine? And what could be done to prevent it? I figure I need to build an additional 100 HP for me to be completely content with my cobalt's power... and this would put me pretty close if I upgraded other things like the flywheel, headers, exhaust, and a few other things like that.
Or is there a more intelligent alternative to this stage 6 kit?
Old Apr 30, 2007 | 09:58 PM
R&C_rallySS's Avatar
Well, imo I think building the LSJ engine from the ground up before throwing small pullies on the stock blower and going with some extra major hp, like 100 more is a must first. Maybe I'm just old fasion and always go with the safe way. Good luck no matter what you choose.-
Old Apr 30, 2007 | 10:10 PM
braddddddd991's Avatar
true that man
Old Apr 30, 2007 | 10:11 PM
Mikey851's Avatar
No that's not old fashion. The bottom end, aside from the crank could use an upgrade before that kit. Also, I would feel it a waste to put that kind of kit on and not at least get a mild P&P and a specific cam grind.
Old Apr 30, 2007 | 10:18 PM
spaz's Avatar
Header and full 3" exhaust ,Zex spk plugs.Don't bother with a intercooler sprayer .(They don't work very well on water to air coolers.) You are going to run water/meth. injection.
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
