any1 got a pic of cobalts pedals?
Those are them, obviously add a clutch pedal for the SS.
I had a question for anyone that has these pedals actually...after installing them does it take away some of the distance between the brake and the gas? It would be helpful to be able to heel-toe on the track since you're supposed to shift before you enter the corners instead of having to downshift in the corners but you lose too much time if you can't heel-toe in order to bring the revs up before you downshift. I was hoping these pedals would decrease the vertical distance between the two. Also, can they be installed both as a replacement (old pedal off, new one on) and also installed over the existing pedals? That would be my second choice for a solution, just replace the brake and clutch pedals and install the gas pedal over the existing one.
Turbo Johnny
Feb 21, 2019 09:41 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
