any1 use windshield washer fluid res for meth?
any put their meth in the washer fluid resevoir? If so what was the easiest way to get it out to tap it and where did you put your pump?
i taped mine on the car with a reverse drill bit, nothing was in the tank at all, and to be on the safe side i filled it up with water a few times and let it drain out. pluged it and she was golden. you still will be able to wash yours windows with the bottle, so there should be know loss, i have a built motor and Im using a 8gph nossel and i still only have to fill the tank up like once a week, thats with it engauging at 11lbs all the way threw 23lbs.
