Anybody running OTTP Stage 4 cams?
Old Jun 27, 2014 | 08:38 PM
  #51
Spawne32's Avatar
Originally Posted by mrbelvedere
zoomer why don't you all offer better cam sets
I would assume it all depends on core availability from whichever grinder they are using, which seems to be comp. I dont know what LSJ/L61 core availability is like but i'm sure web or schneider or even delta could accommodate their needs.
Old Jun 30, 2014 | 03:18 PM
  #52
Zooomer's Avatar
Supporting Vendor
Originally Posted by Spawne32
What are you using to measure the cams that you say are out of spec directly from comp?
Old Jul 2, 2014 | 08:37 PM
  #53
Speedytec's Avatar
Is it an idea to simply ditch the LSJ cam gear ridge/slot and start using the Saab sprocket and timing method for those misalligned Comp cams?
(Saab B207 has no sprocket ridge and it can rotate freely over the cam. Camshaft is alligned/timed with special cam locking blocks (kent moore part) and then sprockets are tightened to the cams with crank in BDP position. reinstall the two cam bearing caps; done. Alfa uses a similar timing method for their cam install.)
We now time our comp cams with those Saab gears, but still using the dial gauge method as there are no locking blocks (yet) available for the ZZP-LSJ profiles...
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
