Anyone change their own oil yet?
I am looking at changing my oil here soon. I went and bought the filter except it wasn't a canned filter. All it was is the paper cartridge. I see there is a filter can in the front under the hood but to get to it, I would have to remove some tubing and maybe other stuff. Is this the proper thing to do or is there a better way? Looks like the oil changing is going to be a real dread..... Good thing I only change my oil when the oil life system tells me too...
I'm not going to bother to change my own oil. I do it in my other cars but the Cobalt I leave to the dealership because it only costs $10 more and they do it in 30 minutes or less. If something else happens, it's there fault and they fix
Change it yourself... It's very easy. Just unscrew the top and it comes right out, there is nothing to move... Oh, and I wouldn't trust a dealership with doing anything that I couldn't do... That's when they nail you with hidden fees and stuff. Plus if you do it yourself you can put the oil you want in there (MOBILE 1!!!)...
I agree.. I don't trust anyone to even change the oil. They either don't let it drain out fully, don't change the filter, leave the fill cap off, stick cheaper oil in there or some other screw up. You can't even verify they changed yoru filter very easily in the SS/SC like you could with most other cars.
Unexperienced people who don't give a crap about respecting your car do the work, especially with oil changes. It's a crap shoot everytime you let someone else do it. I wish you guys luck who let the dealership do it. Hopefully you don't need it. I'm sure many of you will have no problems, but I just can't take that chance anymore.
i did my oil change to day lol and it isnt that hard guys. drain oil. put plug back in. get the cup socket for the filter and an extention with ratchet. losen filter pull it out put new filter in and retighten. 6quarts of oil. reset oil life. boom done
heres the how to
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/oil-filter-6096/
and thread getting moved to the appropriate forum
ToFU you are not using mobil1???????? See ya warranty. If you are not even using synthetic your engine is going to blow. Especially since it came form the factory with
Mobile1 in it. Hoe you have enough $ saved for a new engine
Royal Purple is also a synthetic. If I'm not mistaken it has been rated to perform as good or even better than Mobil 1.
However, I have to question "absolutely loving" it. I'm not trying to be a smart ass Tofu but what are you talking about?!? It's motor oil.
I change my own oil. I'm still using Mobile 1 because I can get it down the street at the local auto parts store.
Originally Posted by tiny
plus, unless you lube it yourself (which most people dont)
then ur missing out on a vital part of maintenance
thats why im not gonna change my oil myself
anyone else notice this is back from july.. hope he changed his oil by now.
anyway its really not hard to do it yourself buy a filter and oil you want then it take like 15-30 mins based on how well you know what your doing.
Maybe placebo effect, but my car idled a lot better w/ the royal purple than it did w/ the Mobil 1.
Originally Posted by dimeo09
lube what... we dont have grease fittings
another "tip" dont tighten it too tight because the oil filter expands with heat, when it starts feeling harder to turn just go in another half a turn.
When I first changed my oil back in May, I also thought it was weird to see just the filter w/o the can, but that's the way she came. On my 2.2, you don't have to take off any tubing or any scary components - all you've got to do is take the plastic engine cover off and unsrew the cap. It won't take too long, however, when you screw the filter back in, make sure to get the threading right - it might be plastic, but if you're in crooked it's a bitch to get out w/o stripping the threads and causing all kinds of nasty ****. Believe me, I speak from experience. Also, as the rest of the people said, get SYNTHETIC and don't be a douche, change it yourself!
Also
Royal Purple IS NOT a GM approved synthetic oil
It cuurrently does NOT meet the GM4718M standard as outlined in your owners manual
Currently the only GM approved oils are (as of May 2005):
-Mobil 1
-Chevron Supreme Synthetic
-Texaco Havoline Synthetic
Using anything that is not specifically approved by the GM4718M standard, puts your engine warranty at risk.
HTH
WopOnTour
Originally Posted by Josh_877
i think he was talking about putting oil around the oil filter ring before u put it on.
