oil filter
Old Sep 29, 2005 | 02:29 PM
chevyguy1990's Avatar
oil filter
when removing the oil filter, what happens after you unscrew the black cap? will oil spill out when you take it off? and what size filter does the 2.2 ls model take? if anyone has a pic, that would help out too.
Old Sep 29, 2005 | 04:25 PM
97cavie24ls's Avatar
if the car has been off for a little bit , no oil should spill out , but you will drop oil if your not carefull when pulling the cap/filter off , as the filter cartrage will still have some oil in it , and drip alot
filter # im not sure of , i never pay attention when i get it from the dealer
Old Sep 29, 2005 | 05:51 PM
the cap comes off and the filter unscrews the a threaded shaft right??
Old Sep 29, 2005 | 06:00 PM
RedCavyRS99's Avatar
Moderator Alumni
ok here is your answers
unscrew the black cap its just a top oil wont spill out
pull the filter straight up (it will drip)
filter number is
STP: S9018R
Fram: CH9018
GM: 12579143
then push new filter back in
screw top back on
Old Sep 29, 2005 | 06:12 PM
the filter should be stuck in the cap when you pull the cap off , atleast the 1 on my g/fs cav always is
unless i got it backwards , LOL
im floating around at work in serious need of some sleep right now , LOL
Old Sep 29, 2005 | 06:19 PM
Moderator Alumni
nope it attaches to the base not the top
Old Dec 20, 2005 | 10:00 PM
Sarbae's Avatar
I drive a 2.2L... doing my first oil change and the filter is stuck to the cap... I've been fiddling with it for over an hour, and I can't seem to get it loose. Any help would be greatly appreciated.
Old Dec 20, 2005 | 10:23 PM
retrop's Avatar
Just did my oil over the weekend. Given i have the 2.0 i just pulled the filter off the cap it came off pretty easy and there is nothing to break.
Old Dec 21, 2005 | 01:46 AM
Sarbae's Avatar
The filter has notches into which a few radial tabs on the cap lock, so I can't see how pulling could free the filter. I had to cut the filter and pry the tabs open. No damage done to the cap, but as far as I can tell I'll have to destroy the used filter every oil change; oh well, not like I'd re-use them anyway.
Old Dec 21, 2005 | 03:07 AM
Malaclypse's Avatar
Those tabs hold tension on a lip inside the cap. You just have to pull harder. Either that or try pulling the filter off at an angle.
Also, if you drain the oil before you remove the filter you won't have any oil spillage at all.
Old Dec 21, 2005 | 03:22 AM
Sarbae's Avatar
Yeah, you're definitely supposed to drain the oil first. I guess I just wasn't pulling hard enough (yeah yeah) but I was pulling pretty darn hard and I definitely didn't want to damage the cap. Also, the drain plug was fixed insanely tight... made me consider multiple times that I was opening the wrong bolt. Either way, changing the Balt's oil wasn't fun ... I miss my raised s-10 blazer
Old Dec 21, 2005 | 04:46 AM
Malaclypse's Avatar
^^ You just need a bigger wrench.
Old Dec 21, 2005 | 07:07 AM
Sarbae's Avatar
I didn't want to hurt her
Old Dec 21, 2005 | 12:21 PM
R33P3R007's Avatar
360 L337 User
just use a bigger wrench... or join a gym.....wuss J/k
anyway it sucked getting to the filter. but didn't take me long
Old Dec 23, 2005 | 08:40 PM
Erod's Avatar
Moderator Alumni
Moved to 2.2 performance, as the post was originally about one, and as this is not a How-To post.
Old Dec 23, 2005 | 11:16 PM
Erod's Avatar
Moderator Alumni
and there is no general "performance" section.
Old Dec 24, 2005 | 10:46 AM
rm25x's Avatar
uhh, changed mine twice now, and each time it just snaps off the cap. It doesn't take much effort. there's no reason to have to cut the old filter apart.
Old Dec 27, 2005 | 01:07 PM
importkiller's Avatar
What oil come stock in the 2.2L and what have you guys been using.
Old Apr 7, 2007 | 12:43 PM
usmpsoldier4life's Avatar
Stupid question but...
It's my first time changing my oil on my 2.0 where is the oil filter at on the car? Thanks.
Old Apr 7, 2007 | 12:49 PM
NinjaHampster's Avatar
under the ride side of the supercharger(other side from the pulley). you will see a black cap with a hexagon shape on it. thats where your filter is located
Old Apr 7, 2007 | 01:06 PM
anyone know what size the oil cap is for a socket?
Old Apr 7, 2007 | 01:08 PM
creasent
Old Apr 7, 2007 | 02:04 PM
Red07SSNA's Avatar
32MM socket -- you can get a specially made socket at Pep Boys (RiteFit#2572) or Auto Zone that are very short. Also a 1 1/4" six point socket will work.
no_ss
Oct 18, 2015 11:58 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
