Anyone Have Any Problems with Gasket!!
Old Jan 18, 2007 | 10:31 PM
dza39's Avatar
I'm about to put on my new ZZP header, is there a certain gasket I should use for it or just use the factory one or a new replacement one from GM? Should I use the bolts or head studs for the header? If studs, where do get some? Anyone having any problems with the factory gaskets? Thanks....
Old Jan 19, 2007 | 12:05 AM
c24na's Avatar
Re use the stock studs/nuts, but throw some antiseize (never seize) on them. As for the gasket, the stock gasket is more then adequate, unless they header is known to leak and needs a special gasket.
Nate
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
