Anyone Have A Throttle...
The only potential advantage for a port injected engine is that if you have a spacer made from a phenolic material, you will transfer less heat from the engine into the throtle body which would theoretically give you a cooler air charge. That is because the spacer would be acting to insulate the throttle body from the convected heat.
teampruven
May 22, 2010 09:54 AM
