Anyone install a EGT (Pyrometer) yet?
Old May 12, 2007 | 12:32 PM
c24na's Avatar
Hey guys,
with all this speculation of whats going on w/number 4, i'm going to go ahead and installed an egt gauge on number 4. Will install the bungs on all the tubes, so i can change it around to see if its getting hotter etc. But I never installed one on my s/c cavy, so its new to me. First hurdle is to get a 0-2000 or 0-1600 sweet cobalt gauge. When i get a chance (little guy goes down for a nap) ill try to research what kind of exh. temps ranges to expect.
But any input would be great. Also planning on sticking a mech. fuel pressure gauge to the end of the fuel rail, so when 60s go in, i can see if there really is a drop.
Nate
Old May 12, 2007 | 12:46 PM
WSFrazier's Avatar
Local guy did it here when he went to straight Turbo swap. I was also going to do this soon, so I will be talking to him about it.
Old May 12, 2007 | 01:10 PM
CobaltSS313's Avatar
i havent done it yet but i plan on doing it in the near future. i dont know which one to tell you to get personally id go with the 2000* gauge
Old May 12, 2007 | 03:05 PM
Rodimus_Prime's Avatar
yup ill be doing this when i get my zzp header and taking the 5v signal off it and plugging that into the aeroforce guages
Old May 13, 2007 | 12:29 AM
c24na's Avatar
Theres no way to run that into the hpt logger is there? Also, any idea what kind of temps we should be aiming for?
Old May 13, 2007 | 12:38 AM
spaz's Avatar
I have one and it gets up just above 1400*f on hard pulls it is mounted in the header about 3-4" from the head.I don't know how accurate it is cause when I shoot the header with an i/r temp gun it was reading 300*f less.I have another pyro I am going to try I just don't have any time right now to install it. I have the cobalt 0-1600 cobalt gauge and there is no ouput for logging.
Old May 13, 2007 | 12:41 AM
c24na's Avatar
Cool. I just bought the same gauge. And would think that there might be a 300* diff from the pyro being inside vs outside of tube temp. Also, i'm planning on putting bungs on each one so i can chance its position if need be. Is it just a 1/8npt thread or is it a special bung?
Thanks,
Nate
Old May 13, 2007 | 12:42 AM
actually its totally possible to run it into Hp tuners, its done the same way as wideband as long as your EGT is based on a 5v signal which many are not , as far as temps, no idea i need do some research on it
im pretty sure though anything above 1600 isnt good
Old May 13, 2007 | 12:49 AM
spaz's Avatar
It is based on a milivolt signal from the pyro sensor. The gauge I got had a 1/8 pipe fitting and a tapered fitting that you can clamp on. I uset the tapered fitting and welded it to the # 4 primary pipe.Then there is a hole in the center where the probe goes through with a set screw.Kinda cheesy the old ones had an actual threaded pyro sensor. The temp output of the probe changed quite a bit depending on how deep i put it in the pipe so I tried to center it somewhat.
Old Aug 23, 2007 | 08:19 PM
NGalaxyTimmyo's Avatar
Alright, since you all have had experience with this, I'm just gonna ask here and not start a new thread.
I'm going turbo, and I'm gonna be ordering a EGT gauge soon. Now most I've found so far are 0-1600, but I've found a few from 0-2000. I know that anything over 1600 is not good at all, but what do you think would be the more reasonable one to get?
Old Aug 23, 2007 | 08:50 PM
Jmc007's Avatar
You can get this very accurate wideband air fuel meter and it can also log the EGT with a pyrometer, that's the one I've just ordered a couple of days ago :
http://www.zeitronix.com/Products/zt2/zt2.htm
Old Aug 23, 2007 | 09:12 PM
Area47's Avatar
Rent me! per hour
i have one, it is 1.5 inches away from the head in number 4.
ultra light 2. it is a 0-2k gauge
Old Aug 23, 2007 | 11:56 PM
how high of temps do you hit on it?
Old Aug 24, 2007 | 01:01 PM
Area47's Avatar
Rent me! per hour
highest ever was 1475
Old Aug 24, 2007 | 01:09 PM
sweet. Thanks. That makes it a bit easier to pick then
Old Aug 24, 2007 | 04:38 PM
M-Dub's Avatar
I am running a 0-1600 Autometer Ultra-Lite gauge, and I am usually in the 1350-1400 range, fill in here Squish if it was different!
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
