Anyone Seen This Cx Racing Heatexchanger On Ebay!!!!
Mine came with just bar stock with slots drilled in them. Kind of a universal fit type deal. You just need a vice to bend them how you want. I didn't use them because they were only 6" long. 1/4" aluminum bar stock from TSC or ACE is my bracket of choice.
Hey, i'm ordering one as well. In that second pic, that tab that the brackets are setting on, could those be drilled to bolt the brackets to. Could you do a detail pic and instructions when you install. Example--> What hose is the outlet on the stock he, and how you hooked it up?
They have real high quality stuff. My only complaint is they let the puddle get too big on one of the welds on an intercooler i got from them. Not really a problem, but just something I noticed. Also, those tabs on the side are meant to be drilled out and used as mounting points.
Yep, np. Not to hijack your thread...but I'm looking for peoples' opinions on this: https://www.cobaltss.net/forums/appearance-48/cowl-induction-hood-100179/
Im so getting one of these towards the end of the month. I might just leave it on the coffee table and buy a second one for the car they just look so damn pretty!
You can use the heat exchanger to run more consistent times, and to be able to run high boost. You tune the methanol to run an extremely aggressive tune. Advance the timing with the methanol until the MPH stop increasing at the dragstrip. That is your sweet spot. Bigger heat exchanger with methanol is more than twice as good as just a heat exchanger, or just methanol. They work together and the output is even better.
damn i was lookin at these, oh well got a cobra H/E now
oh by the way i'm running dual pass, with option "B" and will be adding the H/E and meth later on, they say you dont need the endplate, but i recommend it- it runs the car ALOT cooler.
Last edited by Mnatvyc1223; Mar 9, 2008 at 06:23 PM. Reason: Automerged Doublepost
