Anyone Seen This Cx Racing Heatexchanger On Ebay!!!!
Old Mar 9, 2008 | 11:29 PM
  #51
bender's Avatar
When it comes in, can you see if there are threads on the inlet/outlet..or if it is just a bung.
Old Mar 20, 2008 | 07:02 PM
  #52
advise's Avatar
it's just barbed ends no theads
Old Mar 20, 2008 | 07:07 PM
  #53
madmark's Avatar
very easy to install but you have to cut a 2 inch rectangle out of the impact bar for it to work properly.
Old Mar 20, 2008 | 07:36 PM
  #54
bender's Avatar
Ok. With no threads, you will have to weld AN fittings on, or just use a hose clamp. Or.... just use rubber hose. Are you installing it inline with the stock HE, or are you running this one as a stand alone?
Old Mar 20, 2008 | 07:42 PM
  #55
madmark's Avatar
one side goes from the engine to the heat exchanger, and the other side goes to the pump and they clamp with rubber hoses
Old Mar 20, 2008 | 11:03 PM
  #56
bender's Avatar
I understand that. I was just curious if anyone was running this one in series with their factory HE, or if they were replacing it with a more efficient one. If it were me, I'd just use one, but I've seen some people run the ones from the Cobras inline with their factory ones.
Old Mar 21, 2008 | 02:12 AM
  #57
Hockeyman's Avatar
my CXRacing h/e is being used with my factory one in series.
Old Mar 21, 2008 | 07:06 AM
  #58
bender's Avatar
Are there any known HE's that are big enough to be run on their own? That is w/o spending 500.
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 21, 2015 11:57 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
