areoforce gauge
There are two types you can get.
1: Analogic: Provides hookups for 2EGT Probes, and 4 Analog sensors.
2: Interceptor: Recieves data from the OBD2 port, and has 2 hookups for Analog sensors.
Interceptor, can also read your codes, reset your codes for your CEL and alot more.
I have a dual intercept setup, with an Analogic
It looks pretty cool in a stock sedan a pillar.....IDK i think its cool to play with is it necessary, prolly not but it does show u cool stuff, like when our low fuel light goes on, we have 2 gal. of fuel left.....our cat temps, gear your in, intake temp, knock retard.....those r the ones i like, there are prolly 20 more other parameters u can watch.....some dont work with our cars, like fuel rail pressure.
which one would u recomend then i was black face with blue led lighting i took back my mechanical boost guage today cause i could not get it to work so just seeing which areoforce u would suggest and 2 other gauges i could use to fill my holes thanks
That will fil up three holes...
Unless you plan on adding more then 4 sensors though
2 Interceptors is really all you need.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
