Ask your water meth questions here
Old Sep 16, 2010 | 12:08 PM
  #51
Fidget's Avatar
Originally Posted by Fidget
Is it save to run meth on a car that has 120,000 miles on it?
Any thoughts on this??
Old Sep 16, 2010 | 12:22 PM
  #52
devilsown's Avatar
Originally Posted by 383_Stroker
I am currently running a 6gph Nozzle with a 75/25 mix (sooo.. 4.5ghp methanol). I am pleased with the amount of timing i can pull on this mixture, however I'd like to see my IAT2s drop further.
So, I was thinking about running a 10gph nozzle on a 50/50 mix (5gph methanol?) which will keep fueling similar, but send in lots more water for better cooling i would think?
Is my logic sound here?
Thanks!
No body really makes a 6gph nozzle. Your more than likely running a 5gph nozzle. Some other companys since they don't mark them will sell 1 nozzle with 2 differnt flow rattings. I would go to a 7 first before going to a 10. Even when lowering the mix from a 75 to a 50 then you will be running more water threw the motor. Usually people do run more meth as they increase nozzle size. This is because a motor can only injest so much water.
Originally Posted by SunburstSS
Lets say i get my car hptuned for meth, and i run out of it, will the car run differently since it doesnt see the higher octane that it is tuned for or will it go back to normal 93 octane or whatever it's set to, im asking just in case the system malfunction or breaks or anything.
Your iat sensor will remove timing when the intake air temps go up. This is also another saftly feature.
sweet good to know, thanks for the info dude coz im definatly considering meth injection soon before i get the car tuned !
let me know if you have any other questions.
Old Sep 16, 2010 | 01:34 PM
  #53
383_Stroker's Avatar
Well, my nozzle is a 5gph, but it's rated at 100psi.. and my pump is 150psi.. So i was doing some creative rounding.
Thanks for the imput!
Old Sep 16, 2010 | 01:44 PM
  #54
light'bolt's Avatar
My car has 120k on it and I'm still running meth.
Is there a way to clean the nozzles while they're still inline? Plus what's the best way to clean the nozzles if I don't have a sonic cleaner.
Old Sep 16, 2010 | 04:28 PM
  #55
Fidget's Avatar
I figure something that keeps the motor cooler plus more power can't be a bad thing. Does the meth cause any harm to the sc? I heard it removes the coating on the screws.
Old Sep 16, 2010 | 11:47 PM
  #56
firepinch's Avatar
Hmmm... I'm affraid to ask this question because this has been somewhat discussed in another tread in which Zoomer came in. No flames intended but...
If we want the MOST power, ZZP Performance has made a challenge that nobody has taken yet. The question is: From what mixture do you begin to see a real increase in power...
For example: Does a 80% meth and 20% water mix has the potential of giving the highest horsepower given that the tuning is 100% optimized?
How about 100% meth with a big 10 GPH nozzle... even if a 100% meth mixture is less good for cooling... still, with a 10 GPH nozzle, would the cooling side still good?
Old Sep 17, 2010 | 12:01 AM
  #57
Zdeuce4's Avatar
i have a question as well..
when mounting the setup... ( i have the base kit with the adjustable pressure switch.. should i mount it in my aluminum charge piping or get that o-ring tap thing u guys sell and mount it on my coupler? i was considering that because im kinda nervous about drilling into the charge piping. a coupler is easier replaced.
Old Sep 30, 2010 | 08:46 PM
  #58
SunburstSS's Avatar
Talking
I had a trunk mounted methanol kit before and I had no problems with it, i got a new kit however its the one that i gotta use the washer fluid resevior is ok to mount the pump in the engine bay ? Or the pump will not not move the liquid ? I've attached a picture with the area marked, the fluid resevior is underneath it. I have the DVL-8031 pump
Old Dec 21, 2010 | 06:01 PM
  #59
devilsown's Avatar
Zdeuce4
directly in the tube will work
SunburstSS
your fine to mount it that way the pump will pull the fluid.
Any other questions let me know. Sorry for not keeping up with this tread.
Old Dec 21, 2010 | 08:14 PM
  #60
SunburstSS's Avatar
Zdeuce4
SunburstSS
Lol i figured that out already haha, thanks for the response thou ! the kit works perfecto
Old Dec 21, 2010 | 08:57 PM
  #61
mongorat427's Avatar
Heres a good way to mount it.
Originally Posted by mongorat427
Old Dec 21, 2010 | 09:14 PM
  #62
I used one of those add a circuits in one of the empty fuse holders thats connected to the ignition on for power. Theres a couple empty fuse holders in the fuse box behind kick panel on the passenger side of the console. Relocated the horn into the inside fender well behind the headlight. I picked up 6 MPH at the track after Vince tuned me for it.
Old Dec 22, 2010 | 06:19 AM
  #63
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
I see that you don't ship your pre mixed meth outside the united states. Being that I am in Germany with an APO address, I really don't have any clue on how to find methanol for this kit which is deterring me from purchasing.
Are their any other companies that you could reccomend or solutions to locating some methanol?
Sounds like im looking for drugs. LOL!
Old Dec 22, 2010 | 07:15 AM
  #64
Find a trucking co or truck garage. Sometimes they have it.
Old Dec 22, 2010 | 07:33 AM
  #65
It's difficult with the huge language barrier. I'm picking up a few words and phrases here and there.. It would just be easier if they could ship to my apo LOL. It's probably not legal. LOL
Old Dec 22, 2010 | 02:30 PM
  #66
devilsown's Avatar
mongorat427
that a nice looking install.
since its flameable it can't go by plane. It would be way cheaper for you to find it local. You can use denatured alcohol "ethanol" even rubbing alcohol
Contact this guy. info at baade-motorsport.eu
He is a dealer for us in german and he should be able to help you out he does write english pretty well.
Old Dec 31, 2010 | 12:40 AM
  #67
importkiller's Avatar
Which kit should I get for a SS turbo with an intake, charge piping(hot side only), and a high flow catted down-pipe with a tune. I still have the stock MAP sensors.
Old Jan 3, 2011 | 02:51 PM
  #68
devilsown's Avatar
you can run either out 2.5bar kit our our stage 1 kit. Both will work for you but i do like the progressive setups better.
Old Jan 3, 2011 | 02:54 PM
  #69
PsychoCam's Avatar
I am buying a 2.5 meth kit and I have a 2.2L turbocharged. since I have a stock 1 bar map will the 2.5 bar controller work on my car?
i was told I use a vacuum line instead of taping into my map sensor
Old Jan 5, 2011 | 02:19 PM
  #70
devilsown's Avatar
You will want our dvc30 kit or you will want to buy a 2.5bar map sensor out of a ss and wire it up to just give our controller a signal.
Old Jan 5, 2011 | 07:28 PM
  #71
Joemaster70's Avatar
Im going to install my 2.9,42's and i will probably get Meth but can i just go with the base kit for now and then add on the rest to make a progressive, whats the pros and cons of base to progressive, Will I really loose Power or gain Heat?
Also does the instructions show different ways to install or do i have to figure it out?
Old Jan 12, 2011 | 04:39 PM
  #72
devilsown's Avatar
Yea you can go with a stage 1 setup and later purchess the controller to make it a stage 2.
I like the stage 2 setups because they will let your turn the sytem on at lower boost ranges. Yes you will see a very noticable decrease in lowering your iat temps. This is where you will partcial see the power gain from.
There are differnt instructions for stage 1 and for stage 2 they can both be found on our website.
Old Feb 21, 2011 | 05:55 PM
  #73
subd for later reading, lots of great info to help me with my install.
Old Feb 23, 2011 | 07:54 PM
  #74
redcobalt07's Avatar
Hey guys noob question but I can still run 93 pump gas octane right? Also how would this effect my emissions for inspection?
Old Feb 25, 2011 | 10:02 AM
  #75
devilsown's Avatar
Yes you will still run full octane. You should not have any issues with it for inspection. These are carb exempt. They will even pass threw in CA
