Astronomically high iat2 temps
Old Apr 14, 2014 | 01:52 PM
soaxin's Avatar
So I have a 2007 lsj with 100k miles on it with GM Stage 2 76mm pulley intake and full exhaust. They other day it was 80* outside and sunny so I couldn't resist doing a few pulls. On my 3rd pull my torque app alarm went off and I glanced over and my IAT2 temp hit 200*F! O.O
Old Apr 14, 2014 | 01:53 PM
LNFTX's Avatar
Intercooler pumps are notorious for not working properly or at all I would start there
Old Apr 14, 2014 | 01:54 PM
yellowsupercharged06's Avatar
your pump isnt working i bet .....
turn the car on and look at the T-neck in the front, if no fluid is moving = dead pump
get under the car and smack it with a rubber mallet, pump should kick on and fluid should flow threw your t-neck.
next, order a pump from zzp and replace it ....
there are tons of threads on this .. do a little research.
Staged07SS's Avatar
Administrator
Administrator
GM Stage 3 Pulley is 76 mm....
Check your I/C Pump. With temps like that, I bet it's dead.
Also, I would set your app to alarm you well before you get near that temp again.
Above 140-150, the car will start to pull timing due to excessive IAT2 temps.
Old Apr 14, 2014 | 02:02 PM
blueLNFftw's Avatar
And dont do back to back to back long pulls.
My car is set to cut boost off at 165 degree IAT2.
As said, your pump is likely dead.
Old Apr 14, 2014 | 02:10 PM
soaxin's Avatar
Thanks I posted in panic without searching sorry. I hit the pump absolutely nothing happened. I kniw its def the stage 2 pulley. Forgot the metric value. Ill order a boch pump. Thanks. So a vad ic pump can do thay? My iat2 is at 155 normal driving with a 82 iat1
Old Apr 14, 2014 | 02:11 PM
Staged07SS's Avatar
Administrator
Administrator
77.9 mm S2 pulley.
155 is way high for normal driving. Def get a new pump.
Old Apr 14, 2014 | 02:17 PM
yea rule of thumb with h/e and opt b. is 25-30* above iat 1 while cruising.
Old Apr 14, 2014 | 02:22 PM
soaxin's Avatar
Thanks for the info everyone ill get a pump asap. If I baby it will I be okay? Its a daily so I gotta drive it untill the pump comes in.
Old Apr 14, 2014 | 02:28 PM
yea i mean if it gets up around 155 its going to start to pull some timing, .... just dont beat on it
Old Apr 14, 2014 | 02:30 PM
soaxin's Avatar
Alright thanks. At stop lights it will rise to 162 untill I move again.
Old Apr 14, 2014 | 02:32 PM
yea i mean its going to get high, cuz right now with out a pump you have no intercooling.
but if you just drive it nice an normal and dnt boost and beat on it at WOT u will be ok.
try smacking it again a few times ... sometimes it takes a few good whacks
Old Apr 14, 2014 | 02:45 PM
soaxin's Avatar
Thabks for the info!
Old Apr 14, 2014 | 06:16 PM
mrbelvedere's Avatar
check the fuse
Old Apr 14, 2014 | 06:41 PM
TStone's Avatar
I laughed at the title of the thread
Old Apr 14, 2014 | 07:04 PM
tuned08ss's Avatar
His iat2 is OVER 9000!!!!
Old Apr 14, 2014 | 07:30 PM
soaxin's Avatar
I thought it would be an amusing title. Gotra have a good eye catcher. Haha Fuse and relay are good pump iss completely dead. Orderd one from zzp.
no_ss
Oct 18, 2015 11:58 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
