ATI problems
Old Feb 3, 2014 | 04:23 PM
mrbelvedere's Avatar
ATI problems
ok this is ATI interference problem #2 ill start with mine the hub was hitting the front cover the heat caused from the hub hitting the cover caused the crank seal to come out and **** oil everywhere and introduced metal into the engine this needs to be checked
metal shavings on hub
rub ring
hub installed on zzp machined cover
my advice is to separate the hub from the dampener and check it I would recommend atleast 0.040 or more clearance between the two and this is for the O.D. unit
Old Feb 3, 2014 | 04:27 PM
Hockeyman's Avatar
sub'd
Old Feb 3, 2014 | 04:38 PM
Gunney_07's Avatar
Sub'd I wonder if the lnf and turbo ati will have this problem
Old Feb 3, 2014 | 04:48 PM
Subd for when i install mine
Old Feb 3, 2014 | 06:06 PM
Tjolley's Avatar
I macined the front of my cover down flush with the seal
Old Feb 5, 2014 | 11:57 PM
SSfamilywagon's Avatar
Good to know
turbochargedss2012
Sep 20, 2023 12:17 PM
cw383
Sep 30, 2015 12:41 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
