ATI super damper (over-drive)
Old Apr 26, 2016 | 01:50 PM
jdbaugh1's Avatar
Those of you that have installed an ATI OD harmonic balancer did you have to do any machining to your front cover as ZZP indicates on their website? If so, how much did you really have to machine off for proper clearance?
Any other difficulties in installing the ATI? What kind of tool did you use to press it on?
Old Apr 27, 2016 | 09:08 AM
mrbelvedere's Avatar
yes get the cover from them
Old Apr 27, 2016 | 09:27 AM
jdbaugh1's Avatar
You know of a picture or anything that would show me how much material actually needs to be machines off? If at all possible I would like to just modify my stock front cover plate myself.
Old Apr 27, 2016 | 09:41 AM
yellowsupercharged06's Avatar
google it ! from your questions it sounds like your better off buying one already modified for your sake.
Old Apr 27, 2016 | 10:34 AM
jdbaugh1's Avatar
I googled it as the dick head above suggested and it doesn't look like taking that little bit of material off will be too difficult. I didn't know my questions came off as me being incompetent, I just like to cover all my bases before I get into something. Trying to see what people have done and how they did it. I guess I should just keep my mouth shut and take the easy road because I don't know everything there is to know about this subject already.
I'm sure I asked some stupid questions before I built my engine but I got through that just fine. I'm learning as I go here.
Old Apr 27, 2016 | 10:41 AM
jdbaugh1's Avatar
Picture I stole from internet and highlighted machined portion
Old Apr 27, 2016 | 03:10 PM
07blackg5's Avatar
Slobodan Milošević
the issue is that ********* don't realize that if you take off too much material, it will crack under oil pressure. It's a lot easier to over-do it up than you think.
Old Apr 27, 2016 | 03:32 PM
jdbaugh1's Avatar
I hear you and thanks for the helpful information. I think as long as I take off the bare minimum and not create any stress risers I should be alright. The main thing with these kinds of projects is not to get in a hurry, take my time, and do it right.
Now I just can't decide is while I have that cover off if I should just go ahead and do a balance shaft delete, install neutral balance shafts or just leave it stock and try to limit my time in the upper RPM range.
Old Apr 27, 2016 | 06:38 PM
Bluelightning's Avatar
Got Bewst?
I clearanced mine myself with an air tool and bit. Just took off a little bit at a time until it was good. As for putting it on I just stuck a heat gun in the shaft for a bout 5 min and it slid right on.
Old Apr 27, 2016 | 09:19 PM
I went the zzp route for 100 bux it was like 'meh whatever'
more important as you may or may not have read is to machine the crank for a bigger keyway, so that you don't risk shearing the keyway off and being in big trouble.
Old Apr 28, 2016 | 12:59 AM
YelloEye's Avatar
ZZP sells theirs for $180 now.
Machined Front Cover for Ecotec 2.0/2.2/2.4L
Old Apr 28, 2016 | 08:15 AM
jdbaugh1's Avatar
It's a little higher priced than that now. I need to save more to help pay for that pricey ATI.
Now onto the keyway. Are you saying the ATI comes with a bigger keyway than stock? Or are you saying I need to get both the crank shaft and the new ATI pulley machined to accept a bigger keyway so that it can handle more torque? I haven't seen anything about this yet.
Old Apr 28, 2016 | 09:09 AM
he is referring to extending the keyway making it longer if the stock key shears you loose the oil pump
Old Apr 28, 2016 | 09:50 AM
jdbaugh1's Avatar
I don't remember from when I changed the timing chain for sure but would that require machining on the crank shaft or do I just need to get longer keyway stock?
Old Apr 28, 2016 | 01:59 PM
Got Bewst?
You would have to get the crank machined
Old Apr 28, 2016 | 02:43 PM
jdbaugh1's Avatar
Dammit. That would require taking out the entire crank too I would assume. What a PITA.
Old Apr 28, 2016 | 07:21 PM
Got Bewst?
I've personally never had an issue with the stock key way.
Old May 2, 2016 | 01:49 PM
advise's Avatar
i sheered mine
Old May 2, 2016 | 07:47 PM
63 Nova SS's Avatar
How about the new fluidamper, does it require all that hassle? I had one on my old sbc and it was a good damper. I know pwerks sells them.
Old May 2, 2016 | 07:58 PM
Got Bewst?
They don't do their job on high rpm
Old May 2, 2016 | 07:59 PM
Got Bewst?
Originally Posted by advise
i sheered mine
Well you're pushing on a whole nother level lol
Old May 10, 2016 | 02:38 PM
jdbaugh1's Avatar
Does anyone know where I can find torque specs for installing all of the LSJ belt driven components? My car has L61 but I am swapping over to LSJ belt routing.
Old May 10, 2016 | 05:45 PM
Got Bewst?
LSJ build book. Google it and you'll find it somewhere
Old May 11, 2016 | 10:23 AM
jdbaugh1's Avatar
Thanks. I found a link to LSJ build book chapters 1-6.
For some reason cobaltss.net won't let me link to red!ineforums.com. http://www.(TYPE IN red!ineforums).com/forums/performance-modifications/46184-gm-build-books-pdfs.html
Old May 11, 2016 | 11:42 AM
Probably because of forum wars back in the day. We won :p
thewafflesareburnt
Cobalt SS Vendor Reviews
Apr 20, 2016 07:39 PM
Haven07
Apr 20, 2016 10:13 AM
jdeshong
Apr 19, 2016 02:46 PM
Stumpy
Apr 18, 2016 04:51 PM
cOHbalt
Apr 13, 2016 12:20 PM
