autometer cobalt mechanical boost gauge
Old Jan 26, 2011 | 12:22 AM
insylem's Avatar
Originally Posted by red06SC
I still don't understand why people swap the factory gauge....something to do?
Yup
Because we can...
I wanted mine to read Inches Hg ABSOLUTE
The factory gave me PSIG and InHg Vaccume....
Old Dec 29, 2011 | 02:32 AM
YelloEye's Avatar
Digging this up because I found the solution without buying a dimmer. Just wire in a resistance of 4.2k to get approximately the correct lighting with the Sport Comp II gauges.
Old Apr 1, 2012 | 03:33 PM
nissanrcr12's Avatar
hi guys i just signed up today with a quick question i have a 06 cobalt ss 2.0 supercharged that just last night when i hit boost the gauge stuck around 5 psi and it will not come back down is there any way to fix this or do i have to buy a new gauge? any help on this would be appreciated thanks
Old Apr 1, 2012 | 06:45 PM
YelloEye's Avatar
Sounds like your gauge came unplugged or you popped a fuse. You can try pulling the A-pillar cover off and make sure everything is plugged in.
Old Apr 1, 2012 | 07:26 PM
advise's Avatar
you can dim the gauge if you wire into the dimmer wire forgot which one
because the four wires are power ,ground ,dimmer ,and boost signal
Old Apr 1, 2012 | 08:22 PM
where exactly is the fuse located at? it works when i hit full boost but it will not come down any further than 5 psi
Spanky's Monkey
Mar 7, 2016 06:06 PM
royce777
Sep 28, 2015 07:11 AM
allpro666
Sep 23, 2015 07:47 PM
ashalle2
Sep 16, 2015 10:36 PM
