awkward issue w/ iat and PS
Old Mar 18, 2011 | 08:19 PM
Black SS 07's Avatar
i let my car is over winter, took it out one day when it still had some snow on the ground.. got stuck w/ my summer tires lol epic fail. i tried my best to get it out but along the line the motor went haywire the vac would bounce between -20 and 0. then die after it hit 0 would make the car miss until it shut down. i then attempt to start it up again and the "power steering" came flashing up. not sure what the relation is between the 2.
i havent had a chance until today to mess with it and hook it up to the scanner and what i found was the iat was at 154* when the car first started when it was clearly.. not a 154* out. and had a iat performace code. cleared the code. car ran fine but still read 154*-160* iat
any ideas? just a bad iat?
Old Mar 18, 2011 | 08:21 PM
Leafydialupking's Avatar
Iat2? Would explain the weird vac readings as well. TMAP wiring or sensor.
ecot3c inside's Avatar
Iat2? is this upon the very first startup?
Old Mar 30, 2011 | 04:19 AM
im thinking its the wiring. gm replaced the harness and sensor a year and a half ago.
the iat2 code doesnt pop up right away it takes about 2-3 start ups before it notices it. then a couple days ago i got a maf code. so hoping its just the wires.
anyone know where i could get a harness cheap? lol
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
