B&M short shifter question
Old Oct 22, 2005 | 12:00 AM
shcwv's Avatar
i installed this shifter and i liked it for the first day of normal driving. then when i was racing, i shifted into 4th, it wouldn't go into gear, but it would go into every other gear. then when i was driving normally, it was fine. it is only 4th gear that is doing this. does anyone know of what the problem might be? i am gonna go take a look at it tomorrow and see if i can fix it, or better figure out what the problem is. thanks
Old Oct 22, 2005 | 02:56 AM
Tofu's Avatar
Whats up man? Good seeing you at the aldine meet tonight. I think the problem is the two cables (the ones you have to snap into place) are a little off. I'm pretty sure the left side (closest to drivers seat) is for reverse, and the right side is for the rest of the gears. It's hard to describe typing out, but I had the same problem...I had to unclip the cable and "set" it a little closer down the cable...wow that probably makes no sense.
Old Oct 22, 2005 | 02:15 PM
shcwv's Avatar
yeah it was tight seeing another cobalt, its cool getting all that attention huh? haha, well i am gonna go see if i can mess with the shifter. thanks for the help, i'll let you know if i fix it. i need to catch your number tho TOFU.
Old Oct 27, 2005 | 12:50 PM
shcwv's Avatar
i shortened the cables and i am still having the problem, should i go even shorter?
Old Oct 27, 2005 | 05:17 PM
codyss's Avatar
I will have to look but one cable moves when you go left to right and the other when you go front to back.
Both control all gear selections.
Take a peek at one of my earlier posts using search. There are instructions on how to adjust them there.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
