Balance shafts above 7000 rpm
Boostins thread got me wondering: Has anybody had problems with the stock balance shafts when routinely going above 7000 rpm? Id like the peace of mind having the neutral shafts but the install looks like a bitch to me. Wanted to know if its worth it
Had a friends cobalt that ran stock shafts from day one and reved it to 7500 to 8000 all the time on the weekend. Six months ago he blew the motor from a bent rod so balance shafts didn't break it so not sure.
Well I wanted some opinions because I was gonna see if I consider them driveable daily, I have a motor out of my car and I thought it would be a good way to pick up 10in hp and not have to worry about installing then later
I have been spinning my SC 2.4l to 7200 for the past 4 months with no problems and another member said he has been doing it for 3 years. The LE5 balance shafts are heavier than the LSJ shafts as well:
http://zzperformance.com/products_img/1143_2.jpg
I would think the LSJ engine will handle high rpms much better with the lighter shafts/shorter stroke/forged parts. In a 2.4l Pontiac Solstice stock tune file, the stock rev limit is 7200 and that car has the same springs as the LSJ and heavier shafts. If I had an LSJ, I'd rev 7400 with stock shafts and not worry.
On a side note, if you have performance engine/trans mounts you may not want to do neutral shafts. The vibes I get with my poly mounts are pretty heavy for a dd under low rpm load.
I've done the LZM Balance shaft delete (not neutral shafts) on both a 2.2 and a 2.4. The vibs are slightly increased, but I also have a solid urathane engine and trans mounts and no interior...which makes it much worse.
My car is not my daily, but I take it to work often enough it might as well be, it also gets driven on 10+ hour trips to the drag strip on weekends. Its not unbareable by any means IMO.
GM recomends removing them or installing neutral shafts after 7000rpm I do believe. Remember they spin at 2:1 the engine RPM, so at 7000rpm they are spinning at 14,000rpm. Thats alot of RPM for a significantly unbalanced mass to be spinning at.
I removed mine for peace of mind, as I rev both motors out to 7600rpm. They also free up a considerable amount of power, which is never a bad thing.
As for the guys looking to get Supertech springs, they don't fit into an LSJ head without clearancing the valve spring pockets. The spring contacts the cylinder head casting at the back of the spring (closest to the lash adjuster).
You will need to remove material from the head in order for the springs to fit....just a heads up.
Also, all Ecotec variants (L61, LE5, LSJ, LNF, LAP) all use the same valve springs, GM PN#90537032.
Just wanted to clear up some information.
I have all the info in from my GMR Stage 3 kit.
On a side note:
I have heard of many people installing the supertechs in the lsj head w/o any modification. There could be casting variances though, and that could have been your issue.
LNF's on the other hand def need some modification.
I've deleted mine and retained the water pump chain setup. I have an lsj. on stock mounts the vibs really aren't even there. I can't notice anything rumbling or vibs really at any rpm. I have a full exhaust, that may be my sound resonation, but overall it is very driveable. I've got the zzp springs and spin 8k.
