Which Belt? 2.8" + Phenolic Spacer
Old Apr 26, 2012 | 02:25 PM
Owen S's Avatar
Hey guys, mid-install right now. Which belt should I use? GM stage 2? or stick with stock. I have a 2.8" pulley, and a phenolic spacer right now.
Thanks!
Old Apr 26, 2012 | 02:35 PM
1AJeremyD's Avatar
Im running stock atm if that helps with those mods. Another guy that was there with me got finished before me and tried to put his smaller belt and it would not fit. I've had no slippage or anything on the stock belt
TStone's Avatar
Either would work.. just depends how much effort you wanna put into it.. a stock belt shouldn't slip on that set up though
Old Apr 26, 2012 | 04:42 PM
Owen S's Avatar
wow. getting so angry. how do you get the damn belt off?
Old Apr 26, 2012 | 04:45 PM
1AJeremyD's Avatar
15mm open ended wrench on the top of tensioner. Push forward towards the fire wall to release the tension
Old Apr 26, 2012 | 07:24 PM
Owen S's Avatar
^Thank you. Read that somewhere else and figured it out.
Now I can't get the pulley off...
I think I'm giving up on the pulley/injectors today. just doing the cooling mods for now
Old Apr 26, 2012 | 08:06 PM
hhrfreek's Avatar
I think you should do the Stage 2 belt. I was using the phenolic spacer with a 2.9" and the stage 2 worked.
Old Apr 26, 2012 | 08:09 PM
574's Avatar
574
What are you using to get the pulley off?? You can get a pulley puller from autozone.
Old Apr 26, 2012 | 11:01 PM
nhanson's Avatar
You have much clearance from S/C to rad support?
Old Apr 27, 2012 | 01:05 AM
hhrfreek's Avatar
i clear everything np cept the hhr has the coolant reservoir in the front of the engine bay and the sc actually touches it with the spacer...I might look into relocating that
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
