benifit of useing 5 bolt hub vs 4?
Old May 17, 2010 | 10:53 AM
rockstarbass1's Avatar
I'm ordering a 2.9 pulley and have a 5 bolt smooth flow aka nates hub or my gm stage 2 hub.. was going to just go with a 4 bolt pulley and sell the smooth flow stuff. Is there a dif between the 2? Or a reason I should do it dif?
Old May 17, 2010 | 12:14 PM
Dainslaif's Avatar
No improvement between the two, it's just a design difference. If you already have a stage 2 hub on your car just get a 4bolt pulley from Nate.
Old May 17, 2010 | 12:17 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you cant go smaller than a 2.7 inch pulley on a 4 bolt hub. you can go down to 2.5 inch on a 5 bolt smoothflow hub
Old May 17, 2010 | 12:38 PM
Frew's Avatar
you sure josh? Im pretty sure my buddy has a 4 bolt 2.5, just requires machining down the snout
Old May 17, 2010 | 12:39 PM
I have both the 4 bolt and 5 bolt hub... the 5 have a 2.7 on it I can't use that its too small I'm buying a 2.9 and didn't know what style pulley to get. I'm guessing put it on my stage 2 hub and sell the smothflow hub and pulley
Old May 17, 2010 | 12:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yep, couldnt go lower than 2.7 on my gm2 4 bolt hub
Old May 17, 2010 | 12:50 PM
Staged07SS's Avatar
Administrator
Administrator
You can go down to a 2.5" on nates smoothflow 4-bolt (GM style) hub.
http://www.smoothflowpulleys.com/Stage_2_hub.html
That's correct.
Last edited by Staged07SS; May 17, 2010 at 12:50 PM. Reason: Automerged Doublepost
Old May 17, 2010 | 01:19 PM
Dainslaif's Avatar
Yea, if you have a stage 2 hub on there already just get a new pulley and sell the smoothflow parts.
Old May 17, 2010 | 02:34 PM
Nighthawk243's Avatar
Considering you're only going to 2.9 and the fact that it is a pain to have to press the hub off, I'd say just stick with whatever is on there.
Old May 17, 2010 | 02:52 PM
Staged07SS's Avatar
Administrator
Administrator
Agreed !!
Old May 17, 2010 | 05:32 PM
umm i dont need to press anything off... i have 2 snouts... one has a smoothflow hub on it.. thats onthe sc right now.. then on the spare snout i have the gm hub with a stage 2 pulley on it... either way its take a few bolts off and bam done... just what one do i wanna keep what one do i sell
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 29, 2015 01:53 PM
Bohb
Sep 27, 2015 09:11 PM
