Best clutch for me?
Best clutch for me?
Ok as much as I would love to get the 1100 dollar exedy I cant afford that so im looking for something like centerforce dfx or act or the cheap exedy whats the best clutch/flywheel combo for me as cheap as possible something better than stock.
Why do you want a lightened flywheel?
I'm running the gmpp clutch. I though it gave me trouble at the track the other day but now I think it was just wheel spin. It holds a lot more than expected.
i would think it can handle up to 320 tq?
i now have the gmp clutch, very easy to drive and holds quite well, no complaints
if you drive it like an idiot you can toast a $4000 triple cf disk clutch with 10% of the power rating
are you talking about my post referencing the extra weight buffering out the energy spikes? if so .. sir, you are the dumb one.
to put it as dumb as possible:
take a 6 pound bowling ball on the ground and hit it with a croquet hammer and see how far it goes. then do the same with a 16 pound bowling ball and see how far it does not go. same principle.
Whatever you upgrade to, I recommend adding the GMP upgraded slave cylinder/throw-out bearing (gm part # 24242805). You can get it on gmpartsdirect for $57.86, plus shipping. You should also consider replacing the tube that feeds brake fluid to the slave cylinder from the slave distribution block (gm part # 24422067). You should be able to get it from the dealer for about $10. The cost of shipping from GM Parts Direct for that little piece costs more than the part.
Btw, I might be swapping my Spec 3+ and Spec flywheel for the GM upgrade and OE flywheel.
